D series turbo questions
Old Feb 24, 2005 | 05:24 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default D series turbo questions
Forgive me if I sound naive, please someone help me out.
I want to turbo my sohc vtec, what parts should I purchase, so that I can have a reliable 8 psi turbo daily. I want to rebuild my block and run a block guard, I know I need new rods, and I also want to buy new pistons and rings.
Can I get some help, so I can start sourcing out the parts in time for the summer
thanks all
Old Feb 24, 2005 | 05:48 PM
SOHC_MShue's Avatar
Default Re: D series turbo questions (MugenHonda)
you don't need to build anything in your block to just run 8psi
Old Feb 24, 2005 | 05:52 PM
93turbo16's Avatar
Default Re: D series turbo questions (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to build anything in your block to just run 8psi</TD></TR></TABLE>
right, just good management.
Old Feb 24, 2005 | 05:55 PM
MooreBoost's Avatar
Default Re: D series turbo questions (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
right, just good management.</TD></TR></TABLE>
You can run 8lbs on an FMU/pump just fine.
Old Feb 24, 2005 | 06:00 PM
PistolStarta's Avatar
If you have money to do what ur saying run 12 lbs daily.
Old Feb 24, 2005 | 06:12 PM
Timmay's Avatar
Default Re: D series turbo questions (TurboHatch93si)
depends, 8lbs on what turbo?
my sohc was making 244 whp on 10lbs with a t3/t4 , that is a bit much for stock internals.
with a good piston/rod/bearing combo and good tuning your sohc can handle 3-400 whp just fine
now if you just have a small turbo 8psi you can use a fmu and colder plugs and be ok. or even a V-afc and a good fuel pump
good luck!!
Old Feb 24, 2005 | 06:19 PM
93turbo16's Avatar
Default Re: D series turbo questions (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">
You can run 8lbs on an FMU/pump just fine.</TD></TR></TABLE>
That isn't true in all cases... my car was leaning out nicely with an FMU and pump... It all depends what size turbo you have on there.
Why not just put uber on it..
Old Feb 24, 2005 | 06:25 PM
MugenHonda's Avatar
well my motor has 130k and i don't know if it has been beaten or not.
I want to do a mild rebuild
What rods pistons and rings do you guys reccomend?
Any shop in the tri state and can partake in this
thanks
NY area i mean
BTW, i need more specific answers.
i appreciate all your help, I'll post up pics in may once I get all my parts settled
being in college sets stuff back.
Old Feb 24, 2005 | 07:15 PM
oxSLEEPERxo's Avatar
do a compression test first before u decide to invest in turbo parts
Old Feb 24, 2005 | 07:44 PM
jdm 94 eg freek's Avatar
I need help with my mini me setup i have pieced to gether a turbo setup and i would like to get some info on shaving the block on my d 15 b block
Old Feb 24, 2005 | 07:54 PM
93turbo16's Avatar
Default Re: D series turbo questions (jdm 94 eg freek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm 94 eg freek &raquo;</TD></TR><TR><TD CLASS="quote">I need help with my mini me setup i have pieced to gether a turbo setup and i would like to get some info on shaving the block on my d 15 b block
Um.. how is this relavent to anything..??
The search button is in the top right hand corner. Search mini me swap.
Old Feb 24, 2005 | 09:42 PM
SOHC_MShue's Avatar
Default Re: D series turbo questions (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">depends, 8lbs on what turbo?
good luck!!</TD></TR></TABLE>
damn that is some serious power at 10psi . When did you fully spool?
Old Feb 24, 2005 | 09:45 PM
Timmay's Avatar
1st gear i couldnt get over 7 lbs, but right when i hit second full boost.
from a roll in 2nd id have full boost before 5k, maybe 4500-4700?
Old Feb 25, 2005 | 07:06 AM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">That isn't true in all cases... my car was leaning out nicely with an FMU and pump... It all depends what size turbo you have on there.
Why not just put uber on it..</TD></TR></TABLE>
So put a different ratio disk in there...
Old Feb 25, 2005 | 09:10 AM
BlackCRX's Avatar
might want to invest in some arp head studs to make sure your head doesnt lift
Old Feb 25, 2005 | 09:43 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">1st gear i couldnt get over 7 lbs, but right when i hit second full boost.
from a roll in 2nd id have full boost before 5k, maybe 4500-4700?</TD></TR></TABLE>
haha sweet man
grappler
Jan 4, 2007 12:53 PM
ReggieGrip
Feb 28, 2006 09:34 AM
yz125rider21
Jan 19, 2006 08:40 PM
roots01
Feb 2, 2004 01:45 PM
TurboAce
Jul 16, 2003 05:21 PM
