Oil pressure.....gauge question
Old Jan 20, 2002 | 02:54 AM
MestizoRacer310's Avatar
Default Oil pressure.....gauge question
how much psi does the f22 put out?
Old Jan 21, 2002 | 03:51 AM
urbanlegend21's Avatar
New User
Default Re: Oil pressure.....gauge question (TeamDynasty91AccordEX)
regular operating temperature:
at idle- 69 kPa (0.7 kgf/cm2, 10 psi minimum)
at 3,000 rpm- 340 kPa (3.5 kgf/cm2, 50 psi minimum)
Old Jan 21, 2002 | 06:56 AM
Default Re: Oil pressure.....gauge question (urbanlegend21)
So what gauge would you guys reccommend......the gauge that goes up to 100psi?? what about oil temp.....???
Old Jan 21, 2002 | 07:07 AM
New User
oil temp= 176 deg Far
100 psi woud be fine
Old Jan 22, 2002 | 03:50 PM
Ok, in a different aspect.....What gauges are the MOST IMPORTANT to make sure your car's running right......I was told 1. Oil Pressure, 2. Oil Temperature and 3. Voltmeter...........any others that I should plan on getting?
Old Jan 23, 2002 | 03:35 AM
New User
compression guage
Old Jan 23, 2002 | 03:46 AM
Big James's Avatar
New User
compression guage
LOL!
I would recommend a EGT if you are running any type of adjustable fuel regulator or fuel computer.
1997GS-R
Oct 16, 2005 03:30 PM
TurboCX
Aug 3, 2003 06:33 PM
sslude
Feb 25, 2003 08:31 PM
coil222
Jul 13, 2002 03:43 PM
DuNkiN
Feb 22, 2002 05:50 AM
