Hondata ECU Code ?
Old Feb 24, 2005 | 03:10 PM
Tiferet's Avatar
Default Hondata ECU Code ?
I have a 1996 Civic with a P-28 ECU chipped with a Hondata S-100. As of today it has decided to run like absolute ****, and the check engine light stays on. I know with a stock ECU I can use a jumper in a little connector under the dash and it will flash the check engine light to tell me what's wrong. I am wondering if the same process applies for the Hondata, and what codes do I use, the ones for a P-28?
Please help, I am about to drive the damn car off a dock if it doesn't start running right.
Old Feb 24, 2005 | 03:19 PM
Tiferet's Avatar
Default Re: Hondata ECU Code ? (drip pan)
BTW: the nearest Hondata dealer is three hours away, car won't make it.
Old Feb 24, 2005 | 04:08 PM
Tiferet's Avatar
Bump so I can fix this
Old Feb 24, 2005 | 05:03 PM
B20TDC2's Avatar
Default Re: (drip pan)
the jumper should still work. you can search ht for codes , the p-28 codes
Old Feb 24, 2005 | 05:24 PM
Tiferet's Avatar
Default Re: (B20TDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">the jumper should still work. you can search ht for codes , the p-28 codes</TD></TR></TABLE>
Cool thanks.
redlseg
May 20, 2005 11:36 AM
Tiferet
Feb 24, 2005 03:19 PM
gloryhog
Sep 3, 2004 07:19 PM
zigs
Aug 7, 2003 08:25 PM
