Speedometer works intermittantly
Allright guys, i need your help.
1995 civic ex
d16z6
ABS
Manual tranny
heres the deal. every once in a while the speedo will jump around -/+ 5 mph. also sometimes it wont work, and when it kicks back on the needle jumps to 100mph and will continue around the speedo until it gets to the stop pin.
what ive done for the time being is taken off the clear cluster cover so when it doesnt work i just flick the speedo and it hops to where it should be.
this really isnt a big problem it just pisses me off.
so if you guys have had this problem or know of a way to fix it without getting a new cluster chime in.
1995 civic ex
d16z6
ABS
Manual tranny
i dont think its a speed sensor bc when it is working, it reads the correct speed. (based on knowledge of gear ratios and engine speed.)
im having the same problem with my LX right now...i got a new cluster...but didn't put it in cuz it was the wrong one
But like stated before...it's either the cluster or VSS sensor.
For some people it's different...just a matter of which one you gonna try to fix first
But like stated before...it's either the cluster or VSS sensor. For some people it's different...just a matter of which one you gonna try to fix first
no. there are not any CELs being thrown.
and ill check the VSS after work tomorrow. since i work at a dealership i have access to lifts whenever i want.
daviss22
Apr 22, 2012 09:19 AM
imadigitalgod
Oct 31, 2004 02:57 AM
