2.5" cutout vs. 3" cutout
Old Feb 24, 2005 | 08:59 AM
Finest's Avatar
Default 2.5" cutout vs. 3" cutout
Any difference in performance from a 2.5" cutout vs. a 3" cutout?
If it makes it any easier, my downpipe is only 2.5". I plan to hook up the cutout about 12" or so from the turbine outlet, so would that extra 0.5" really help out?
Old Feb 24, 2005 | 02:18 PM
Tchleung's Avatar
It would be intereesting to rig up sicen you'd have to get an exhust reducer to change the 2.5" to 3" at the cutout flange. but for the price. go the 3" ebcause if you ever measure the e-cutouts. to ahve clearence for the gate to open. it msut be smaller then the ID of the actual pipping. my DMH 2.5" cutout was actually 2.3" So if you get the 3" it'll atleast be true 2.5"+
Old Feb 24, 2005 | 03:30 PM
CRXDrew's Avatar
Default Re: (Tchleung)
If you have a 2.5 downpipe I would just go get yourself a 3inch downpipe and use the 3inch cutout.
I made a 2.5 downpipe and went with the 2.5 cutout. Its plenty for my 14b 10psi setup. I can't imagine tooooo much of a difference. Sorry, I don't know if that helped any.
Old Feb 24, 2005 | 03:31 PM
CRXDrew's Avatar
Oh and thats a 2.5 inch Summit cutout.
Old Feb 24, 2005 | 05:15 PM
vtekstorm's Avatar
Default Re: (CRXDrew)
not to be rude and jack your post but what is this cut out thing do anyways?
Old Feb 24, 2005 | 05:56 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (vtekstorm)
A cut out allows you to run a full exh. system and pass emissions, when you want faster spool time and more HP, you open the cut out and bam, more power and A NICE sounding exh.
Blaze
Old Feb 24, 2005 | 06:00 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Blaze45)
I wouldnt say it sounds "nice" but its certainly bad ***!
Old Feb 24, 2005 | 07:25 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">not to be rude and jack your post but what is this cut out thing do anyways?</TD></TR></TABLE>
Don't worry about it. We're all here to learn something...
But yea, the cutout (manual or electronic) lets you bypass the rest of the exhaust system and in essence allow you to run an open exhaust (like the one pictured). It also helps if you don't want a loud 3" exhaust or if you need to pass inspections or dodge the police for noise violations.
Tchleung: I wasn't aware that the gate is actually smaller. If that's the case, I'll definitely have to get the 3". Thanks for the heads up!
Old Feb 24, 2005 | 07:51 PM
andysila's Avatar
how does the cut out work.. ?? whats it do to pass emissions?
Old Feb 24, 2005 | 08:03 PM
Tchleung's Avatar
the cutout well, the E-Cutout is wired to a swithc incar that you switch to open the valve and run open downpipe/header. in donig so. you can retain stock exhaust. when you want power. open the bitch up :D
Old Feb 24, 2005 | 08:39 PM
andysila's Avatar
is it really worth it? so then how does it work.. how would it pass emissions
Old Feb 24, 2005 | 08:47 PM
Tchleung's Avatar
Default Re: (andysila)
you coud run as many cats and resoantors as you want to restrict flow and keep emissions down. that's how it can help you pass emissions and still have great power at a flick ofa switch. really simpel setup
Old Feb 26, 2005 | 12:17 AM
TA Performance's Avatar
$30 bucks for a summit racing y pipe.. u cant beat that plus it really good for sleeper, but only thing is u have to climb under the damn car to open it
Old Feb 26, 2005 | 10:42 AM
DurboDug93's Avatar
Default Re: (USDMx05)
get an e cutout
Old Feb 26, 2005 | 02:00 PM
Ls1 FD3s's Avatar
Default Re: (DurboDug93)
hello friggin restriction CITY. That pic of the DP with cutout on it is soooo wrong on SOooo many levels. Wanna know how the real men hook it up?
-in that pic that CRX Drew posted... The tubing that spurs off from the downpipe, which has the threaded studs for the QTP cutout or the removable block off plate. bad idea, totally horrible flow. INSTEAD. hack that flange that has the studs off, weld it at the end of the downpipe (where the downpipe would in theory connect to your catylitic converter) then where the flange once was, route that to your regular exhuast system... This way, you take 100% full advangtage of open downpipe when the cutout is open, and the flow has a straight shot out,and not having to make some awkward *** bend. aka restriction. only downside is, your full exhuast route has been slightly comprimised with restriction, BUT. With my way, now you have 1 way no restriction, and 1 way with some. CRX Drews setup is restrictive both ways. aka no score.
I wish i knew how to post pics, i could better express myself, everybody understand what tried to say? lol
OR you can go with jimbo's custom exhuast. Which is i plan to possibly distribute shortly, its pure player stuff. super light, next to NO restriction, cheap, stealthy, and more!
Old Feb 26, 2005 | 03:09 PM
Tchleung's Avatar
Your explanatio works pretty good. But to some people they wanna jsut run a basic setup liek teh pic psoted which does still work, jsut not 100%.
roller3804
Feb 21, 2012 02:54 PM
the.hamburglar
Sep 18, 2006 05:30 AM
xxscaxx
Jan 4, 2005 04:35 PM
TTWS6.
Sep 10, 2003 02:39 AM
