Is there Type R trailing arm different from the other integras?
Old Feb 23, 2005 | 09:53 PM
k20z's Avatar
* B A N N E D *
Default Is there Type R trailing arm different from the other integras?
or are they the same?
Old Feb 23, 2005 | 11:19 PM
Naruto's Avatar
Default Re: Is there Type R trailing arm different from the other integras? (ROFL COPTER)
If you're referring to the rear trailing arm in which the hub bolts to. There should be no difference. I completed a 5 lug conversion having to use one when two of the four star bolts that hold the 4 lug hub on my DC4 would not come off of the passenger side rear trailing arm. Well...at least I saw no differences and it bolted on just fine.
mofo951
Suspension & Brakes
Mar 22, 2012 03:31 PM
-auSTIn-
Nov 14, 2004 07:35 PM
743power
Dec 8, 2003 01:30 PM
daddymax
Sep 20, 2003 08:39 AM
