changing wheel studs PLEASE HELP!!
I took my car to have some tires changed and they ruined my wheel studs and I am changing them. the studs will not bang out of the hub they hit the back the hub. I do not know how to get the hub off. Anything will help thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChicoAccord2001 »</TD></TR><TR><TD CLASS="quote">Take the car back to where they changed your tires and tell them to replace it or give you money to get it done. </TD></TR></TABLE>
Well said
Well said
unless it's some back hole allie **** that has signs up that says "not respon. for anything broken" i seen some places like that.... stay away from that ****.... go to a pro.... big shop....
Did u try turning the hub so that its facing the area where the caliper would go......and then hammering it out............if u need to remove the hub... u must have it pressed out
Thanks for the info,.. how am I going to know which way the hub is suppose to be for the caliper to go on if the rotor is off?? is there only one way??
jdmtodadc2
Aug 26, 2012 01:21 PM
