Replacing Wheel studs.
Well guys I need some help... I've changed wheel studs before but not on a honda.
I have to change 2 in the front. is there anyway easier than taking the hole HUB apart???
Re: Replacing Wheel studs. (JDM94HATCH)
I heard something about grinding a lil bit off the HUB so you can just get it to come out...
How does this work??
Re: Replacing Wheel studs. (NAlover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover »</TD></TR><TR><TD CLASS="quote">I heard something about grinding a lil bit off the HUB so you can just get it to come out...
How does this work??</TD></TR></TABLE>
thats a loil ghetto the right way is to take the hub out.
but its exactly huw it sounds you grind a lil off the hub so the new studs will fit no problem.
you can sometimes cut alittls off the back of the old studs to pound them out past the hub/bearing. the same can be done when installing the new studs. if you look at the back of the hub you will see where the stud will hit the bearing/hub. just notch the back and pound away.
Re: Replacing Wheel studs. (Snail Tuning)
That sounds better. I know the right way is to take the hub apart, but I don't have too much time for that and I don't thing grinding a lil bit will hurt the hub's performance ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover »</TD></TR><TR><TD CLASS="quote">That sounds better. I know the right way is to take the hub apart, but I don't have too much time for that and I don't thing grinding a lil bit will hurt the hub's performance ...</TD></TR></TABLE>
just as long as you dont grind all the way to the bearings lol
jdmtodadc2
08-26-2012 01:21 PM
ef90b16
11-28-2008 09:36 PM
