Help, broken wheel stud
Old Nov 12, 2003 | 01:10 PM
nEoMuGen's Avatar
Default Help, broken wheel stud
A friend of mine broke his wheel stud because the torque on the lug was way too strong. I took it to my friend's shop and he said that in order to replace the stud, he has to take off the entire hub, which may damage the wheel bearing. Is this true? What would be a better solution? My friend right now drives the car on 3 lugs torqued at 80lb-ft, is this sufficient for everyday city-driving?
Old Nov 12, 2003 | 01:17 PM
CNSK's Avatar
Default Re: Help, broken wheel stud (nEoMuGen)
I got mine broken also and have been driving around for 2 years with 3 wheel studs on the front passenger side. Posted in here last time but no help. anyone??? People who has extended studs....help out....
Old Nov 12, 2003 | 01:50 PM
xyooj's Avatar
take the hub out ang bang the stud out. Put a new one on and vola......done
Old Nov 12, 2003 | 02:02 PM
tilt's Avatar
when you pull the hub it pretty much ruins the wheel bearing. just get a new one. take it to a shop and have them take care of it.
as for driving on 3 lugs i recommend not doing it for any length of time. esp on freeway. one of my lugs fell off and the wheel would wobble quite noticeably.
Old Nov 12, 2003 | 02:28 PM
nEoMuGen's Avatar
Default Re: (xyooj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyooj &raquo;</TD></TR><TR><TD CLASS="quote">take the hub out ang bang the stud out. Put a new one on and vola......done</TD></TR></TABLE>
I know, but the wheel bearing will be effected when the hub is removed. The labor of the hub, wheel bearing removal + the parts will be somewhere above the $250 mark.
Old Nov 13, 2003 | 05:34 AM
CNSK's Avatar
Default Re: (xyooj)
do you even know that your talking about??? the back you can do it but the front is harder. give me some details rather then vola, If its that easy I would have done it long time ago.......
Old Nov 13, 2003 | 05:41 AM
EDoTdc2's Avatar
Default Re: (nEoMuGen)
forget that i have broken severaly studs. it slams right out i didnt have to take my hub off. and then just impact a new one in.
Old Nov 13, 2003 | 05:54 AM
P1mpSlap's Avatar
Default Re: (EDoTdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EDoTdc2 &raquo;</TD></TR><TR><TD CLASS="quote">forget that i have broken severaly studs. it slams right out i didnt have to take my hub off. and then just impact a new one in.</TD></TR></TABLE>
yup
If people took the time to work on their own car, they'd realize it's not really that hard to replace the stuff they **** up.
Old Nov 13, 2003 | 06:17 AM
EDoTdc2's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
yup
If people took the time to work on their own car, they'd realize it's not really that hard to replace the stuff they **** up. </TD></TR></TABLE>
damn straight!!
Old Nov 13, 2003 | 06:24 AM
andrew dc's Avatar
time to go extended studs...
here is a good link for reference:
http://honda.hybrids.jp/tech/p...shtml
Old Nov 13, 2003 | 06:32 AM
Passaudi1.8t's Avatar
New User
The wheel bearing doesn't always get damaged when taking the hub apart. I had 2 snapped studs on the same wheel! and Honda wanted to charge me $400+ to fix the problem. I said **** that, and brought it to another shop in my town. They charged me less than $100 and there was no need for a new wheel bearing. You just need to be really careful when taking the hub apart, and make sure to pack the bearings with plenty of grease.
Old Nov 13, 2003 | 06:45 AM
Takumi Fujiwara's Avatar
Default Re: (Dr.FeelgooDC2)
I went to NTB (National Tire & Batter). They charge the same price up to 5 studs. I bought my own studs and brought them in, they were done in under an hour. It was $50.00.
I broke one, but I thought I'd just do all of them, so I replaced all 4 on my hub. Everything is working fine...
From my understanding, if you have the right equipment (slide hammer or something), the bearing isn't "always" damaged when the hub is removed.
Old Nov 13, 2003 | 07:45 AM
IntegrasGoFast's Avatar
Default Re: (Takumi Fujiwara)
take it to a shop thats what i did when i did the exact same thing (too much torque) it cost like $50 and i didn't have to get a new bearing and stuff.
Old Nov 13, 2003 | 02:25 PM
Harddrnker's Avatar
Default Re: (IntegrasGoFast)
naaaa, just bang it out from the front like said b4 up top. and impact a new on in with a impact gun. price = $1 or $2 or some where around there
Old Nov 14, 2003 | 03:27 AM
JimBlake's Avatar
Default Re: (Harddrnker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harddrnker &raquo;</TD></TR><TR><TD CLASS="quote">naaaa, just bang it out from the front like said b4 up top. and impact a new on in with a impact gun. price = $1 or $2 or some where around there </TD></TR></TABLE>It all depends on where it is. On my '95 in the front, there's not enough room to do that. The steering knuckle doesn't have any kind of cutout to allow the new stud to be inserted. The hub has to be pressed out.
Old Nov 14, 2003 | 07:42 AM
nEoMuGen's Avatar
Default Re: (JimBlake)
Same here, it's on the passenger front. The hub has to be out and wheel bearing might get damage.
Old Nov 14, 2003 | 08:58 AM
player2z's Avatar
It was hard to get off for me, It took me longer than i though, i suggest go to a local shop they charge only 60$ to install a new one.
Old Nov 14, 2003 | 12:06 PM
WhoisDan's Avatar
Just buy used front GSR disc brakes off another car. Some dude on the forum is selling 99 GSR complete front disc brakes for 100. That will solve your friends problem.
Old Nov 14, 2003 | 12:37 PM
EdoMoto's Avatar
Ive upgraded my studs to longer ones and it took me 3 hours to do all 4 corners all you need is a big hammer and tools. I did this on my driveway.
Old Nov 14, 2003 | 03:10 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It all depends on where it is. On my '95 in the front, there's not enough room to do that. The steering knuckle doesn't have any kind of cutout to allow the new stud to be inserted. The hub has to be pressed out.
Exactly what I meant, the front passenger, you can't bang it out and insert a new one in. I'll take it to the shop, **** the hassle
Old Nov 14, 2003 | 03:30 PM
RCautoworks's Avatar
On some cars there is no way your going to get the stud out with out removing the hub. So for the people that say just bang it out, thats not always the case. Anyways if you have to remove the hub, just go rent a slide hammer and pull the hub off like that. Then replace the stud.
Old Nov 14, 2003 | 07:47 PM
J-g-D-s-M-r's Avatar
ive had broken studs before. they replaced it with no problems. never heard about damaging the wheeling bearing.
Old Nov 14, 2003 | 08:28 PM
m R g S r's Avatar
Default Re: Help, broken wheel stud (J-g-D-s-M-r)
I have a broken stud in the rear, would it be worth it to just buy new discs at the same time?? Mine are really worn.
Old Nov 15, 2003 | 03:55 PM
nEoMuGen's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">On some cars there is no way your going to get the stud out with out removing the hub. So for the people that say just bang it out, thats not always the case. Anyways if you have to remove the hub, just go rent a slide hammer and pull the hub off like that. Then replace the stud.</TD></TR></TABLE>
Yeah... on my ITR, there is a hole with threads that you can press out the studs, but not on my friend's LS.
Old Nov 15, 2003 | 04:17 PM
Jimmy's Avatar
Global Moderator
This happened to me on my hatch...
The stud got stripped and would just sit there and spin around and i beat it off...then i went to fix it a few days later...and tried to put the new stud in and my dad convinced me that the ''splines'' in the hub were stripped so i couldnt put a new stud n with out a new hub,etc,etc,...so i still dont know if theyre stripped or not..but i've been meaning to get mine fixed...
streetracer_305
18
Jun 20, 2015 01:59 PM
YoungKadafi
Suspension & Brakes
Mar 10, 2007 05:06 PM
e jay one
Dec 19, 2006 03:52 PM
Ninjaboi_on_X
Mar 16, 2003 07:14 PM
mckenzie
Jul 13, 2002 10:34 PM
