Wireing help anybody?
When installing a aftermarket tach on a vehecle that does not come stock with one, where and what color is the coil wire that I need to wire into my tach? I beleave it is a blue or green wire behind my gauge cluster but is it in one of the harnesses that are currently hooked up to my cluster or is it a wire somewhere in the loom that i need to trace down?
u need to run it to the blue wire on the dizzy........that is where u'll get the best signal.. what year car.. u can get a factory cluster w/tach, it will plug right in and work ....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=949918
little search button goes long way's...
.</TD></TR></TABLE>I did use the search feature, came up with that... which still doesn't answer my question regarding the guage cluster wire....
look at a ecu pin out diagram in the faq section and splice into that wire. a tach install is so easy man. and btw i think that if you use the neg. or pos. wire differs between manufacturers but i'm not certant on that one. is that what your trying to find out?
joecivic93
Jan 6, 2004 10:07 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
