Blue wire mod what color wire on the ecu pin out
Old Feb 23, 2005 | 11:51 AM
Pullig's Avatar
Default Blue wire mod what color wire on the ecu pin out
Honda prelude 95 with the P14 ecu which wire do i clip for the o2 sensor thanks?
Old Feb 23, 2005 | 12:01 PM
The Phil's Avatar
Default Re: Blue wire mod what color wire on the ecu pin out (Pullig)
Grammar owns you.
It's the fat white one. Please tell me you're not just changing all your wires to blue...
Old Feb 23, 2005 | 12:29 PM
Pullig's Avatar
Default Re: Blue wire mod what color wire on the ecu pin out (xthephilx)
no lol its for the SAFC
lol i had planned to run all blue wires cuz they look pretty lol
Old Feb 23, 2005 | 12:45 PM
Pullig's Avatar
what type of sensor is it real quick Karman type or hot wire , flap pressure sensor
Old Feb 23, 2005 | 07:08 PM
Pullig's Avatar
you told me wrong on the O2 wire you told me the one for the Ob2 i needed the Obd1 which is the white and red wire now i gotta go back in there and desolder and redo it all over again
Old Feb 23, 2005 | 07:28 PM
ChrisRicketts's Avatar
misinformation sucks ***. i'd give you the right info......but i don't know.
Old Feb 23, 2005 | 07:29 PM
Pullig's Avatar
Default Re: Blue wire mod what color wire on the ecu pin out (ChrisRicketts)
yeah it does suck as much as i hate soldering wires and splicing the most important wires on my car i gotta do it again tomorw lol i get so worried messin with **** cuz if u loosen a wire man its gonna give u problems all the time
Old Feb 23, 2005 | 07:39 PM
Looking at this it looks like it is the white one.....D14. I know this is the p13 pinout, but the only difference in the p13 and p14 is the vtec. so i'd assume
that the pinout would be the same-----i mean, i think it would still be the d14. i noticed more than just one wire is solid white, so just make sure you are in the right section. i know the solid white is the correct one for O2 on my p5p as well. Hope this helps.
P13 pinout
Contact Color Description
A1 brn Injector #1
A2 yel Injector #4
A3 red1 Injector #2
A4 grn/yel VTEC Solenoid Valve
A5 blu Injector #3
A6 or/wht HO2S heater coil
A7 grn/blk1 PGM-FI Main Relay coil
A8 grn/blk2 Shorted to A7
A9 blk/blu IAC Valve
A10 - -
A11 red2 EGR Control Solenoid
A12 blu/red Condenser Fan Relay
A13 blu/wht MIL
A14 - -
A15 red/blu A/C Clutch Relay
A16 wht/grn Alternator
A17 pink IAB Solenoid Valve
A18 - -
A19 wht Intake Control Solenoid Valve
A20 red/grn EVAP Purge Control Solenoid
A21 yel/grn1 ICM
A22 yel/grn2 Shorted to A21
A23 blk1 GND
A24 blk2 GND
A25 yel/blk PGM-FI Main Relay (power)
A26 blk/red VTEC Pressure Switch (GND)
B1 yel/blk PGM-FI Main Relay (power)
B2 brn/blk GND
B3 - -
B4 - -
B5 blu/blk To A/C Switch
B6 - -
B7 - -
B8 red/grn PSP Switch
B9 blu/red Starter Cut Relay
B10 orn2 VSS
B11 orn3 CYP
B12 wht CYP
B13 orn/blu TDC
B14 wht/blu TDC
B15 blu/grn CKP
B16 blu/yel CKP
D1 wht/yel Battery
D2 grn/wht1 Brake Switch
D3 red/blu KS
D4 brn/wht SCS
D5 - -
D6 lt blu or lt grn VTEC Pressure Switch
D7 lt grn/red Data Link Connector
D8 - -
D9 wht/red ALT
D10 grn/blk ELD
D11 red/blk TP Sensor
D12 wht/blk EGR Valve Lift Sensor
D13 yel/blu ECT Sensor
D14 wht HO2S Sense
D15 red/yel IAT Sensor
D16 - -
D17 wht/blu MAP Sensor
D18 - -
D19 red/wht EGR Valve Lift Sensor
D20 yel/wht TP Sensor
D21 blu/wht MAP Sensor
D22 grn/wht2 TP Sensor
Old Feb 23, 2005 | 07:51 PM
Pullig's Avatar
do u got a pic of what plug corresponds to A , b , d
Old Feb 23, 2005 | 07:53 PM
Pullig's Avatar
looks to me like i picked the intake control solenoid valve ill have to check tomrow o well its not gonna hurt nothin cuz all it does is read the voltage so im not too worried but i will change it tomorw to see wut kinda voltage im gettin
Old Feb 23, 2005 | 08:09 PM
like i said......don't quote me on this because i don't know for sure if the wire placement is different on the p13 and p14. but it should be the same at least in the D section. This is even where it was on my ecu as well.
Old Feb 23, 2005 | 08:30 PM
Pullig's Avatar
appreciate it ill do this tomrow but for now im goin to bed thanks bye
Old Feb 23, 2005 | 09:10 PM
sharkcohen's Avatar
What the hell is a blue wire mod?
Old Feb 23, 2005 | 09:13 PM
The Phil's Avatar
Default Re: Blue wire mod what color wire on the ecu pin out (sharkcohen)
You mod all the wires to make them blue, duh!
I asked the same thing, read the 3rd post.
Old Feb 24, 2005 | 03:57 AM
BB4's Avatar
BB4
theres a ecu pinout in the faq
dstah
Engine Management and Tuning
May 2, 2009 10:13 PM
slammedz6ef
Feb 15, 2008 07:46 AM
InLimbo87
Jul 3, 2004 09:12 PM
dsm this
Mar 15, 2004 02:42 AM
