Z6 stuttering/popping during acceleration, check list of what to look for?
Car is studdering mainly from idle - 4000 RPM or so... but more so the lower end when I am applying the gas a little more. The car is making popping noises then finally comes out of it as ease off the throttle a little. However, once back on the throttle is reverts back to the stuttering etc during acceleration. Any advice would be appreciated.
So far my list to check consists of:
*wires (how do you check the resistance and what values am I looking for?)
*dizzy (check cap/rotor but not sure what else to look for?)
*plugs (doubt this is the problem since I can florr the car fine in the higher rpm range (5000 RPM +)
*plugged cat?? (car seems fine in the higher RPM's as mentioned)
Anything else??
TIA
Anything else??
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso »</TD></TR><TR><TD CLASS="quote">vaccuum leak maybe or maybe one of your plugs are bad or a bent valve</TD></TR></TABLE>
I highly doubt a bent valve, nothing has changed and if the Tbelt skipped a tooth the car would be mangled all the time. I will check vacuum though.
theelemental
Nov 7, 2008 01:37 PM
LoudLude
14
Jan 20, 2006 07:27 PM
oddball327
Apr 25, 2005 01:14 AM
