clutch/flywheel was changed now having problems
Old Feb 23, 2005 | 06:23 AM
TnLude2000's Avatar
Default clutch/flywheel was changed now having problems
I had my clutch and flywheel changed about 400 miles ago and evrytime I try to take off fairly quickly it seems like the clutch slips and theres no pull but if im driving normal I have no issues, does anyone know what this could be??? fidanza flywheel and excedy stage 1 clutch... Also I never thought to check my oil after I got it back out of the shop but noticed that my vtech didnt feel right so I checked the oil and itwas so low that it was barely even on the dipstick... How bad is it that I drove it like that and would any oil have leaked out of my car while they where working on the tranny??? I gave them a new rear main to put in it while the tranny was out... thanks
Old Feb 23, 2005 | 07:04 AM
prelittlelude's Avatar
Default Re: clutch/flywheel was changed now having problems (TnLude2000)
well hopefully they put the rear main seal in right and that it isn't leaking. because that could effect clutch gripage.
if you are having problems bring it back to them and tell them to fix it.
you should be able to rev up and launch in 1st with out any clutch slippage. bring it back while you still only have very little miles on it, so they are more liekly to warrenty their work
Old Feb 23, 2005 | 04:41 PM
TnLude2000's Avatar
the parts store did not have a rear main listed for a H22 so I asked on honda-tech if one for an H23 would work and they said yes because the blocks are the same so thats the one they put in.. Could that be the problem or should that seal work fine? thanks
Old Feb 23, 2005 | 06:16 PM
ChrisRicketts's Avatar
i agree with prelittlelude- you should take it back to them while you still can. did you break the clutch in first?
rich7777
Jan 3, 2011 03:21 PM
jaysome01
Apr 3, 2008 03:55 PM
RICE POLICE SIP
12
Sep 22, 2006 10:31 AM
OpTionET
Nov 18, 2002 06:52 PM
matht27
Jul 16, 2002 04:34 AM
