d16z6 + 14b (5 psi) running beerbongs bin
juz got over wid da project. had some problems with code 13 and 16 initially but managed to get along by disabling injector test, ELD and barometric sensor... am running a p28-g52 - EDM i believe. for the resistor box am using seperate 5W 8 ohms resistors for the dsms
no changes ve been made to the beerbongs bin file with DSM 450's and it runs very smooth. plugs turn out to be normal. idle circle is a bit rich whereas the tip shows a perfect combustion. dont ve access to dyno or a wide band and i guess its better than running the AFC hack...
raced one mazdaspeed Rx-8 and i was ahead about 2 car lengths. will be posting vids by tomorrow...
Licensed2Spool
May 28, 2002 08:25 PM
