stupid ? but what size t bolts do i need?
i want the connection to be tight... but i don't want to buy a t-bolt that's too small or too large...
for my charge piping being 2.5"... please consider the thickness of the silicon hose coupler too...
so do i get the 2-1/4 - 2-9/16" or the 2-1/2 - 2-13/16" t-bolts? (inner diameter of my silicon couplers = 2.5")
I ordered some 2 inch couplers from ATP turbo, and the 2.25 inch t bolts i got were too small. I had to send them back. But the 2.5 inch t bolts fit the 2.25 coulpler fine.
if you coupler is 2" then get 2.25inch if you coupler is 2.5" get 2.75 if you coupler is 3" get 3.25 simple as that
The silicone coupling is 0.125" thick on my ride. I'm running 2.5" charge pipe...that makes for a total OD of the coupling 2.75"....go with the ones that open to 2.8125" and you'll be happy.
SOHCD16y8
Dec 25, 2005 07:37 AM
if i use 2.5 inch i/c piping. which t bolt clamps do i use, and what size silicone couplers do i use
B16Civic93
Jul 4, 2005 05:09 AM
