PROblem with driver wINdow 97 hatch
Old Feb 22, 2005 | 08:31 PM
2ndGenREX's Avatar
Default PROblem with driver wINdow 97 hatch
hey my sisters got a 97 civic hatch an the window keeps coming off track.... i've takin it apart and put it back on track but for some reason the track seems to may be bent......or i dunoo.... anybody else having this problem?? any way to fix it?
Old Feb 26, 2005 | 05:10 PM
sschouest's Avatar
Default Re: PROblem with driver wINdow 97 hatch (2ndGenREX)
same with mine.......it is very hard to fix....but there is a better remedy...
when you put down the window.....go about 5inches at a time...then pause...you can see it, it will slowly go back onto track....then 5 more inch...
i put it down 5 inch...push the window down with my hand....then go 5 inch more...then push down...then 5 inch more...push down again
Old Feb 26, 2005 | 05:13 PM
civic-si-2000's Avatar
Lol almost every honda has this problem. My rubber running channel for the window glass was so dry the window was pulling the rubber with it. I put it back together and used some silicone spray on the rubber and it works fine now.
Old Feb 26, 2005 | 08:07 PM
93Civac's Avatar
My window in my 96 hatch jumped off track Thursday, of course it was raining at the time. My front sash that holds the window rubber was bent and the regulator is really worn out. Im going to order a new one from Honda next week. The manual regulator and front sash arent hard at all to replace, not sure about a power widow.
Old Feb 26, 2005 | 10:26 PM
EG1.8cT68's Avatar
Go to your local dealership and buy a new window regulator, all of the 96-00 civics have this problem. Due to this the regulators are pretty cheap- around $55. I believe there are 6 ten mm bolts to remove the reg, and once it is out there is 3-T25? torx head srews that should come with the new reg to remove. Reinstall same as removal and when you are done use a silicone spray to lubricate the run channel(rubber seal the window rides to go up or down) periodically lube this appox. every 15k to keep the regulator rivets from expanding and causing the same issue. Or let your dealer do it for Approx 2 hours labor I.E. $160 plus the reg.
martindj
Oct 16, 2013 08:06 AM
Heru-Ek
Aug 10, 2013 02:32 PM
GuitarPunk015
Dec 7, 2008 11:22 AM
g2man
Feb 12, 2004 02:31 AM
acme
Nov 4, 2002 06:39 AM
