ECU problem and IACV problem
Old Feb 22, 2005 | 04:13 PM
pro547's Avatar
Default ECU problem and IACV problem
OK I have this wierd problem I just converted my y7 to a y5 manual intake manifold and just pinned my IACV and when I plug my ecu(P06) I get a solid CEL and a little Idle problem but drives fine other than that. SO I think that the ecu is fried and cut pin J1 on the ecu and still get a solid CEL so now I'm really thinking that I have a ecu problem so I then I unpin my IACV and now getting a flashing CEL with code 14. It then Idles like **** and is undrivable, sputters.
I did a ODB2 conversion to a ODB1
What do you think the problem is?
Does anyone know if the IACV is suppose to get hot to the touch?
Would my conversion harness or my ECU need anything done to it in order to work with my 2 wire IACV hack?
Old Feb 22, 2005 | 06:10 PM
pro547's Avatar
Default Re: ECU problem and IACV problem (pro547)
bump this forum moves to fast
Old Feb 22, 2005 | 06:17 PM
eK9aT10pSi's Avatar
what code are you getting ?
Old Feb 23, 2005 | 03:00 AM
pro547's Avatar
code 14
Old Feb 23, 2005 | 08:42 AM
pro547's Avatar
bumpizzle
Old Feb 23, 2005 | 12:41 PM
pro547's Avatar
Help Please
Old Feb 23, 2005 | 04:45 PM
eK9aT10pSi's Avatar
Default Re: (pro547)
when you swapped you manifold, was the IACV a 2pin or 3pin ?
Old Feb 23, 2005 | 04:51 PM
pro547's Avatar
I had the y7 which was a 3 wire so when I swaped in the y5 manifold It was a 2 wire.
Old Feb 23, 2005 | 06:17 PM
eK9aT10pSi's Avatar
did you repin it ?
Old Feb 23, 2005 | 06:41 PM
pro547's Avatar
yes but it still idles wierd. I'm pretty sure not the throttle cable.it goes from like 800 all the way to 1700 and keeps doing it. Even after it warms up it still does it.
Old Feb 24, 2005 | 03:41 AM
pro547's Avatar
quick little update:
I figured out what is wrong. I had the jumper on the hole time. But the idle is still sucky Idles very wierd.
Old Feb 25, 2005 | 11:21 AM
pro547's Avatar
bump someone help me please
t3mppa_FIN
Engine Management and Tuning
Oct 20, 2012 06:07 AM
Gavint52
May 9, 2011 03:07 PM
dad0c402
May 5, 2007 08:06 PM
DrewMD
Feb 22, 2007 11:34 AM
2khb
Aug 2, 2004 05:45 PM
