Best engine combonation for a tourqe whore
I have made this post in another forum but got nothing but bullshit so i turn to you guys.
I have a 1991 crx si that i want to make into a tourqey good handling crx
so my question is what kind of mods would i need to do to a b20 to make some good tourqe and h/p
Thanks in advance for any advice...
B20 VTEC or B20 only?
Obviously, to get torque you would follow all the same build up styles of any high HP b-series engine because HP and TQ go hand in hand. Your not going to have a problem getting torque out of a B20. A few things that I suggest for B20 build ups in general is:
PISTONS: I prefer Wiseco but there are many others that are great too. Adding forged pistons to your setup will help deal with the heat that comes from reving the motor passed its designed intent thus allowing you to rev higher safely and extracting a longer power band for more HP and TQ yields. Another hugh plus to aftermarket forged pistons is the valve reliefs. They provide more space between piston and valve which allows you to use larger profile cams than with the small relief OEM pistons.
I dont really have time to go on and on but to make things short I also recommend head work, cams that max out in your rev limit (BC3+) etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">RESLEEVE A H22.. DO AN 89MM BORE
He has a CRX, no H22 for him and im sure he already has the B20. I know you can put a H22 in a CRX but its lots of trouble.
</TD></TR></TABLE>He has a CRX, no H22 for him and im sure he already has the B20. I know you can put a H22 in a CRX but its lots of trouble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crxkid »</TD></TR><TR><TD CLASS="quote">
He has a CRX, no H22 for him and im sure he already has the B20. I know you can put a H22 in a CRX but its lots of trouble.</TD></TR></TABLE>
yes but H22/23 is where the torque is at! H23 VTEC baby!! Ok well for B series personally I would get a stroker kit or go boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseriesboosted »</TD></TR><TR><TD CLASS="quote">I have made this post in another forum but got nothing but bullshit so i turn to you guys.
Thanks in advance for any advice...</TD></TR></TABLE>
Read the mans post. He wants a torquey good handling crx!! You guys are suggesting a H22 and you think its going to handle just as good as a b-series in there!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">
uhh...the h22 is only 40lb's heavier then a b-series motor. 2nd the motor makes more torque then any stock b-series.
Hear you go.Didn't need to look far. https://honda-tech.com/zerothread?id=1141433
Glenn
Glenn
have u experienced the handling differences??
NO u have not obviously....
go either B20/Vtec or Allmotor B20.
You can hit 150+ ft-lbs TQ easy. Raise the Compression(check out endyne pistons, http://www.theoldone.com). And get a good set of cams. If you dont have a lot of money the nonvtec route maybe more up your alley and you still can hit 190-200WHP! Either way in a crx, a B20/Vtec or N/A B20 is going to be a torque monster.
Ihave a 99 civic si coupe the motor is being assembled right now. I was just wondering if anyone would have any idea what kinda numbers id be putting out. i've read lots of articles and forums some say b20 franks normally put out 200 with just the head swap some say more. at http://www.importreview.com/d_2.0.html they got b20 franks puttin out up to 234 hp with less mods than my motor. they also have a 200 hp si coupe @ 200 hp runnin 13.2 that sound about right? heres a list of my mods below. if you wanna check out any pics heres the link http://www.xanga.com/hybrid_syndicate
Engine Mods: (B20Vtec) Built 98 CRV Block, 99 SI Transmission, 99 SI ported & polished head, Crane Stage 2 Cam Shafts, Super Tech valves, Super Tech Dual Titanium valve springs, Super Tech Titanium retainers, AEM Tru Time Adjustable Cam Gears, Apexi Vtec Controller, AEM Short ram intake, 70mm Throttle body, Skunk 2 Intake Manifold, NGK Spark Plug Wires, Zex Plugs, AEM Fuel pressure Regulator, JE Stroker Kit ( JE 11:1 Compression Pistons, Eagle Rods, Eagle Forge Steel Crank),Golden Eagle Oil Line Kit, Jegs Fuel Pressure Gauge, ACT Street Light 12lbs Flywheel, ACT Stage 2 Xtreme Pressure Plate Clutch, DC Sport 4-1 Headers, Hi-Flow Cat,Greddy Evo Exhuast System, Pro 1 Short Shifter, Enjo Urethane Motor Mounts
Exterior: VIS OEM Carbon Fiber hood, VIS Carbon Fiber Trunk, R34 front bumper, Blitz Sideskirts, Buddy Club Rear
it has all most a 4" stroke
