OBD2A & OBD2B sensors
Old Feb 21, 2005 | 04:16 PM
brnyrdcmndo's Avatar
Default OBD2A & OBD2B sensors
I need to know what sensors OBD2B has, that OBD2A does not have.
Reason: I am swapping a 2000 B18C5 (USDM) into a 1998 Civic CX hatchback, with a 1996-98 EX harness (for ease of wiring). i need to know the answer to the above question so I know what sensors I don't need to hook up, but still be able to get an emmisions test.
Thanks!
Old Feb 22, 2005 | 04:35 AM
Default Re: OBD2A & OBD2B sensors (brnyrdcmndo)
Anyone? Should I try a different forum?
Old Feb 22, 2005 | 08:11 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnyrdcmndo &raquo;</TD></TR><TR><TD CLASS="quote">i need to know the answer to the above question so I know what sensors I don't need to hook up, but still be able to get an emmisions test.</TD></TR></TABLE>
If you want to pass emmisions, then you need to satisfy what your ECU is looking for.
What ECU are you using?
Old Feb 22, 2005 | 09:43 AM
sleepyEK's Avatar
only thing i can think of off the top of my head is that the 99+ obd2 uses a tach signal from the ecu not the dizzy like the 96-98 obd2.
Old Feb 22, 2005 | 12:45 PM
Katman's Avatar
I believe all of the sensors between OBD2a & OBD2b US engines are the same.
Old Feb 22, 2005 | 05:58 PM
Default Re: OBD2A & OBD2B sensors (EE_Chris)
I am using a '98 OBD2A USDM ITR ECU.
Old Feb 23, 2005 | 12:07 PM
Bump
Old Mar 9, 2005 | 07:23 AM
Katman's Avatar
You should be fine using the 98 ITR ecu on your 00 B18C5, just make sure you're running all of the 00 B18C5 emissions crap and you should be set...
maomaniarocks
Nov 6, 2008 04:43 PM
RYNO48
Nov 30, 2007 02:27 PM
1.6vx
Jul 6, 2007 01:22 PM
99ekb18b
Apr 15, 2007 09:23 PM
sivik-si
Mar 22, 2007 05:24 PM
