how many of you run your turbo setup without a catchcan?
Old Feb 21, 2005 | 04:08 PM
B16Civic93's Avatar
Default how many of you run your turbo setup without a catchcan?
Old Feb 21, 2005 | 04:25 PM
Speedracer32's Avatar
Default Re: how many of you run your turbo setup without a catchcan? (B16Civic93)
i did
all i had was a hose and fitler attached
plan put on on the next set up if the funds allow
Old Feb 21, 2005 | 04:29 PM
B16Civic93's Avatar
Default Re: how many of you run your turbo setup without a catchcan? (Speedracer32)
what do you mean hose and filter attached? did you have any problems?
Old Feb 21, 2005 | 05:20 PM
platinum00's Avatar
you can either run no cans and vent to atmosphere, or run one. Either way works better then the stock PCV system
platinum.
Old Feb 21, 2005 | 05:26 PM
Tchleung's Avatar
I jsut run a hose from the valkve cover right to the ground, then run a hose from the air/oil seperator also to teh ground with no PCV. Works fine
Old Feb 21, 2005 | 05:30 PM
B16Civic93's Avatar
Default Re: (Tchleung)
well i have a jdm second gen b16a, the pcv valve is in the intake manifold, not the valve cover, i have a little breather filter on the valve cover, that usually goes to the intake pipe, i am n/a as of now. however would i just close off the vacuum port on the manifold, and hollow the pcv valve out and run a hose just to the ground? wouldn't that effect gas milage alot? would that hurt anything?
Old Feb 21, 2005 | 05:54 PM
rocket256's Avatar
im not running one.
Old Feb 26, 2005 | 12:34 PM
h22 civic's Avatar
Default Re: how many of you run your turbo setup without a catchcan? (rocket256)
u r not running a pcv valve at all ?
Old Feb 26, 2005 | 12:54 PM
beepy's Avatar
Default Re: how many of you run your turbo setup without a catchcan? (h22 civic)
I just run the OEM PCV system with an air/oil seperator inline. Works perfect, keeps the oil fresher longer than not using PCV.
Old Feb 26, 2005 | 01:01 PM
2point2's Avatar
Default Re: how many of you run your turbo setup without a catchcan? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">I just run the OEM PCV system with an air/oil seperator inline. Works perfect, keeps the oil fresher longer than not using PCV.</TD></TR></TABLE>
pic?
Bioinfomatic
Feb 24, 2007 03:10 PM
DannyDeuce
Sep 8, 2006 03:46 PM
portenio78
Apr 26, 2005 10:48 PM
darkirony
Sep 26, 2004 07:37 PM
Prelude91siT
Jan 1, 2004 10:42 AM
