dp flange with one hole and niche
Old Feb 21, 2005 | 01:31 PM
RACEPAK's Avatar
Default dp flange with one hole and niche
hello everybody
i remember i saw here on H-T a DP flange for a internal wastegate turbo that has one hole for the exhaust pipe and a small niche so the wg gases can flow above "the wall" that saperets between the WG and the turbo outlet.
are these any good?
i want to make one for my T3.
can somone please post a pic of the flange i'm talkin about for materialization
best regards moshik galimidi
Old Feb 21, 2005 | 02:11 PM
RACEPAK's Avatar
Default Re: dp flange with one hole and niche (RACEPAK)
please help.... i need to go to make the flange
Old Feb 21, 2005 | 10:33 PM
RACEPAK's Avatar
help
Old Feb 21, 2005 | 10:48 PM
wantboost's Avatar
Who is Mr Robot?
you dont want to do it like youre thinking, that will cause the gases to merge abruptly and cause a lot of turbulence in the dp. Just find a flange with two separate outlets, one for the turbine gases and one for the wastegate gases. then i'd just dump the wg to atmosphere
Old Feb 22, 2005 | 12:04 AM
RACEPAK's Avatar
Default Re: dp flange with one hole and niche (wantboost)
do i need to merge a pipe from the wg hole of the flange to the exhaust pipe or do i leave i open to atmosphere?
Old Feb 22, 2005 | 12:59 AM
tegs's Avatar
Either way will work. It's matter of opinion, I've ran both and I could care less which way it was.
Old Feb 22, 2005 | 05:09 AM
RACEPAK's Avatar
Default Re: (tegs)
please more answers
Old Feb 22, 2005 | 06:19 AM
RACEPAK's Avatar
Default Re: (RACEPAK)
just wondering: is it ok to cut the wall?
Old Feb 22, 2005 | 08:29 AM
RACEPAK's Avatar
tt
Old Feb 22, 2005 | 12:24 PM
tegs's Avatar
I'm not sure about the wall, I was referring to dumping in the atmosphere or not. Sorry for any confusion.
Old Feb 22, 2005 | 03:01 PM
RACEPAK's Avatar
Default Re: (tegs)
help
96 GSR-T
Mar 22, 2010 04:18 PM
SD_Lurker
Dec 26, 2007 11:30 AM
AlienKrOZ
Jun 27, 2007 05:53 AM
alex_s817
Apr 13, 2007 12:59 PM
