Valve cover gasket leaking
Old Feb 21, 2005 | 06:05 AM
seifer's Avatar
Default Valve cover gasket leaking
Hey There,
Im losing a lot of oil but its not leaking from the PAN and its not burned through the exhaust...
I noticed my PCV valve was worned out (I shaked it and I hear no bearings) so it might be the cause. But while I was checking the valve, I noticed my valve cover gasket looked to be leaking as there was some oil, could it be the cause as well?
I mean there was just a little bit oil... not that much. Of course I will change the gasket anyway but Im just wondering if the gasket problem is more the core of my oil burning problem than the PCV valve is?
Thanks
Old Feb 21, 2005 | 07:45 AM
JimBlake's Avatar
Default Re: Valve cover gasket leaking (fukushuu)
It could be either one or both. But the thing is, these are pretty cheap & easy to fix. I'd fix BOTH, then go from there. Get sparkplug tube seals too, sometimes they're not automatically included in a VC gasket.
Old Feb 21, 2005 | 08:14 AM
seifer's Avatar
Default Re: Valve cover gasket leaking (JimBlake)
Ok thanks! Im not sure what sparkplug tube seals are visually, but Ill find out for sure!
Old Feb 21, 2005 | 09:40 AM
JimBlake's Avatar
#7, one for each spark plug hole. Sometimes you get the whole set, sometimes you get ONLY the separate gasket pieces. Ask the question when you order the gasket so you know what you're buying...
Old Feb 21, 2005 | 10:10 AM
seifer's Avatar
hey thanks a lot for the details! That's gonna help me out replacing it...
yeah I just called the shop where I ordered my gasket and it does come with the sparkplug tube seals.
All I got left is to do the job! It's my first car, my first "job" in my engine, exept some minor thingies so wish me luck!
Old Feb 21, 2005 | 12:00 PM
seifer's Avatar
hey thanks for the drawing ... would you have the complete link on acuraparts247 by any chance? I could use the howto.
Thanks
Old Feb 21, 2005 | 12:16 PM
itellyawhat's Avatar
where is the oil going? on the tranny?
Old Feb 21, 2005 | 12:24 PM
sleevedgsr's Avatar
Default Re: (itellyawhat)
Same problem here!
Just try to remove & replace spark plug wire set
And try to remove and replace fuel filter.
Old Feb 21, 2005 | 12:32 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fukushuu &raquo;</TD></TR><TR><TD CLASS="quote">... would you have the complete link on acuraparts247 by any chance?</TD></TR></TABLE>I'm not sure what you mean. I didn't know they had any how-to stuff? The pictures are there to help you order parts. Put in your car's year/model/version/whatever & then pick a category...
Old Feb 21, 2005 | 04:54 PM
tremor86's Avatar
Fukushuu, make sure when reinstalling the valve cover not to overtighten the nuts and bolts on the cover. They only get tightend to 9 ft-lbs and it is very common for people to overtorque them and then they have to buy a new stud. Also, you might want to check the cam bore plug for oil leaks because they are very common for leaking and they are right by the valve cover gasket, in front of the distributor. Its a black plastic plug at the end of the camshaft. Check that also. Pm me with any other ?'s
Old Feb 22, 2005 | 03:32 AM
seifer's Avatar
Default Re: Valve cover gasket leaking (tremor86)
Thanks a thousand times! Ill do all that tonight and PM you if needed! I can't wait to have a non oil-leaking/burning car
I'll post heads up on my issue when Im done in case it could help some people.
** JimBlake, Sorry I thought it was a howto site with that kind of image Still thanks for the graphic it's going to help a lot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tremor86 &raquo;</TD></TR><TR><TD CLASS="quote">Fukushuu, make sure when reinstalling the valve cover not to overtighten the nuts and bolts on the cover. They only get tightend to 9 ft-lbs and it is very common for people to overtorque them and then they have to buy a new stud. Also, you might want to check the cam bore plug for oil leaks because they are very common for leaking and they are right by the valve cover gasket, in front of the distributor. Its a black plastic plug at the end of the camshaft. Check that also. Pm me with any other ?'s</TD></TR></TABLE>
Old Feb 22, 2005 | 04:02 AM
JimBlake's Avatar
What engine you got? VTEC? If so, check out this thread for a couple other places where it MIGHT be leaking.
https://honda-tech.com/zerothread?id=1151563
Old Feb 22, 2005 | 06:01 AM
seifer's Avatar
Actually, I saw this thread when it was originally posted and was trying to find it again!! Thanks Jim! I couldn't find it since the search server was down! Thx again (And yes its VTEC --&gt; B18C1)
Rock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">What engine you got? VTEC? If so, check out this thread for a couple other places where it MIGHT be leaking.
Squigget
Feb 8, 2020 07:12 PM
hondachris1994
Mar 1, 2009 07:37 AM
EJ8VTEC
Acura TSX
Nov 7, 2008 01:46 PM
.Ry
Mar 22, 2005 09:12 PM
slowls
Jun 25, 2003 10:24 PM
