Porting worthwile?
Old Feb 20, 2005 | 11:45 AM
sleeperb16a's Avatar
Default Porting worthwile?
What is the usual gain in horsepower by porting/polishing the head on an otherwise stock B16A2? Also, is a half point increase in compression noticeable?
TIA
Old Feb 21, 2005 | 09:06 AM
Default Re: Porting worthwile? (sleeperb16a)
Anyone with back to back tests with unported/ported heads?
Old Feb 21, 2005 | 09:48 AM
mmuller's Avatar
Mad Scientist
.5 gain in compresssion wint really give you much.
you could gain some power by doing a nice valve job and doing some blending of the throats/top cut/ combustion chambers. pretty much just improving on the flaws
Old Feb 22, 2005 | 09:22 AM
Default Re: Porting worthwile? (mmuller)
mmuller,
Shall clean up the casting flaws and perform some bowl work as you suggested.
I have a first gen B16A with auto cams and am planning to install a set of B16A2 manual cams and valve springs. Since the compression is 10.2 compared to the B16A2's 10.4, I was thinking of shaving the head 0.020" in order to increase the compression......what do you suggest? Should I leave the compression as it is?
TIA
Old Feb 22, 2005 | 11:57 AM
dfoxengr's Avatar
pull the middle layer out of your new headgasket if you want to raise comp. dont mill unless it's your last resort to raise comp.
Old Feb 22, 2005 | 01:31 PM
mmuller's Avatar
Mad Scientist
Default Re: Porting worthwile? (hybridvteceg)
yes as hybridvteceg sayd, milling is the last resort for gaining compression.
.2 will not make a difference in power, i would just leave it as is.
Old Feb 23, 2005 | 11:11 AM
OK I wont mill the head and go with a thinner gasket instead.
Thanks guys!
AlwayzSpoolin
Jan 17, 2007 05:53 PM
Slick92GS-R
Jul 14, 2006 06:46 AM
SiShane
May 31, 2004 11:28 AM
Notaverage
Dec 1, 2003 04:53 PM
Unsung
Jun 13, 2002 04:07 PM
