Will this work/do anything much?
Old Feb 19, 2005 | 09:36 PM
coupe99vtec's Avatar
Default Will this work/do anything much?
As some of you know i am converting my D17 LX car to manual, getting all teh stuff i need of antoher car that apparently fell of a truck, its either an 01 or an 02 EX
(fell on its rear end/roof, and rocked ove rthe roof)
Now my question is, if the motor is has vtec (dont even know if it does) can i take the head off of that, (and sum1 mentioned a solenoid) and install that on my car? Will it make my car vtec? and is taht how u get DOHC? cuz from what i heard vtec is only on DOHC??? cuz it utilizes more valves when vtec kicks in?
Anyways if this is even possible, what kinda gain would i notice? Does anyone thing its a bad idea? and why?
Old Feb 19, 2005 | 09:38 PM
Solo2EG's Avatar
Default Re: Will this work/do anything much? (rentacar4dr)
ok, I'm not trying to be a jerk but you don't know the diff between dohc and sohc but you're gonna do a tranny swap? that's not good...
your car, and the donor car are sohc, the only stock (current gen) dohc Civic is the Si hatch... and to answer your other problem, there are dohc and sohc vtec motors...
but yes, in theory, if the donor car is a vtec model you should be able to get everything you need to do that swap too... tell you the truth it would probably be easier just to swap in the whole drivetrain if it's not wrecked...
Old Feb 19, 2005 | 09:40 PM
sohcvtec1995's Avatar
The only way to get dohc is if you get the fluid and add it in with your oil. ITs availble at all Ford Dealers.
But if you can get the tranny and other componets, just swap the motor out. and if you can you need the ecu as well.
Old Feb 19, 2005 | 09:42 PM
Revolver's Avatar
Default Re: Will this work/do anything much? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">The only way to get dohc is if you get the fluid and add it in with your oil. ITs availble at all Ford Dealers.
But if you can get the tranny and other componets, just swap the motor out. and if you can you need the ecu as well.</TD></TR></TABLE>
W3rd. You can pick it up at autozone too. BTW, I wouldnt suggest doing the tranny swap on your own if you dont know this kind of information.
Old Feb 19, 2005 | 09:53 PM
Red93AWD's Avatar
Default Re: Will this work/do anything much? (Revolver)
Hey please let me know what happens cause my vtec does not work cause my cams are not 2 there are only one of them and i really need vtec for my motor to beat my bosses viper cause he is really fast.
Old Feb 19, 2005 | 09:54 PM
Solo2EG's Avatar
Jeez, and I was worried about sounding like a jerk...
Old Feb 19, 2005 | 09:57 PM
Red93AWD's Avatar
Default Re: (Solo2EG)
rentacar4dr are your motor 2 cam jdm?
Old Feb 19, 2005 | 09:58 PM
Revolver's Avatar
Default Re: (Red93AWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red93AWD &raquo;</TD></TR><TR><TD CLASS="quote">rentacar4dr are you gay too? I would love some butt loving. </TD></TR></TABLE>
Old Feb 19, 2005 | 10:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red93AWD &raquo;</TD></TR><TR><TD CLASS="quote">i am a complete moron and need to get a life, i hope i get banned</TD></TR></TABLE>
I hope so to. Go away trool. at least try to help the kid out.
Old Feb 19, 2005 | 10:01 PM
HXvtec's Avatar
Default Re: (Revolver)
yea but if you want to convert your car to manual then your gonna have to change your rear diff. your gonna have to get a posi rear end. oh yea and your gonna have to put special fluid. syncomesh is the best way to go. DOHC runs good with syncromesh
Revolver's Avatar
Default Re: (sohcvtec1995)
I hope so to. Go away trool. at least try to help the kid out.</TD></TR></TABLE>
Look at me! Im trying to get to 3000 posts!
Old Feb 19, 2005 | 10:03 PM
Red93AWD's Avatar
I hope so to. Go away trool. I am a turkey and all I want is 3000 posts so that people will think im cool even though all i do is read honda tech cause i am a turkey.</TD></TR></TABLE>
turkeys go gobababababa
Old Feb 19, 2005 | 10:04 PM
Revolver's Avatar
turkeys go gobababababa</TD></TR></TABLE>
Liquor OWNS you!
Old Feb 20, 2005 | 05:31 PM
what the **** is wrong with you people seriously??
Thanks to those who are helping though.
I am not doing ths myself, sum1 else is doing it, and when u say rear diff, what do you mean? the car is FWD isnt it?
Also what fluid are you talking about, u mean like cooling? or the the clutch? lol i have no clue, i just want to be able to get all my **** togheter before we take the car apart and go aww **** now we have to drive and get the stuff again. (his truck gets like 7 mpg and the shops are far away lol)
i think sohcvtec1995 is just being sarcastic saying that i can get DOH with fluid? FU if ur trying to be a d*ck, otherwise, please explain, cuz solo2EG seems to be the only guy who helped thanks for that..
Old Feb 21, 2005 | 10:37 AM
Default Re: (rentacar4dr)
Yes i was being sarcastic, and dnt f me, FU. i did tell you what to do. If you haVE A NON VTEC MOTOR ie dx, lx. and the donor car has a vtec motor then swap it over completely. if you want 2 cams , then you need to go K series. Vtec is not determined on the number of cams you have, its the number of cam lobes. No you dnt have a rear diff. Here is your list of things to swap over.
1a.entire D17 vtec motor, and tranny, with ecu (Optional and a lot easier)
1b. Tranny
2.Ecu
3. Clutch, flywheel, pressure plate
4.Pedal assembly from a 5 speed.
5.Tranny mount
6.Possibly add new wires or remove some.
7.A friendd that knows what they are doing
8.And Honda tech's niffy Search function
there you go have fun, and be sure to search next time so this dosent happen again. good luck
Old Feb 22, 2005 | 07:55 AM
Thanks for helping out that time sohcvtec1995,
BTW looks like i might be popular with my quote in ur sig
atleast people will know im new to all this.
How long (working at a slow but steady pace) will it take for one experienced person and me to do the mini-me and tranny?
If he has room this weekend we might do it then, said for the tranny he would take it easy and do it in 2 days?? that mean i'll be losing about 20 hrs of work pay, lol
Old Feb 22, 2005 | 04:03 PM
Solo2EG's Avatar
Is the block no good in the donor car??? The reason I ask this is that's the only reason you should mini-me rather than just swapping the whole motor and tranny... it will be waaaaaayyyy easier.
Old Feb 22, 2005 | 04:43 PM
jeef84's Avatar
Mini-me is definitely recommended. There's a ton of stuff on search that you can find once it's back up. BTW, B-series have two camshafts as well.
Old Feb 24, 2005 | 12:08 AM
Revolver's Avatar
Default Re: (jeef84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeef84 &raquo;</TD></TR><TR><TD CLASS="quote">. BTW, B-series have two camshafts as well. </TD></TR></TABLE>
Yeah, but I dont think he'll be putting a B series in that car which is why he only mentioned the K.
matraca112
Sep 7, 2004 10:36 PM
btcca4
Aug 12, 2004 12:45 AM
btcca4
Aug 12, 2004 12:40 AM
crzyfool24
Nov 17, 2003 02:32 PM
J T*
Mar 21, 2002 09:19 PM
