best place for boost gauge and wastergate hookup
Old Feb 19, 2005 | 07:27 PM
radioren's Avatar
Default best place for boost gauge and wastergate hookup
I have a spliter good for two sources on the compressor side. I was thinking boost gauge hooked up somewhere by manifold. How much boost is lost in reality after IC etc till it reaches intake? as for wastegate I figure right at compressor to get acurate reading as well. Or does it really matter? Maybe hook em both up there? Just wanted others opinions. This is a very low boost setup my first just to get started. I would post pic but wehn i do all it says is.... [IMG][/IMG]
Old Feb 19, 2005 | 08:23 PM
MooreBoost's Avatar
Default Re: best place for boost gauge and wastergate hookup (radioren)
Get your gauge source at the intake manifold and the wastegate source right after the turbo, or after the intercooler and before the throttle body.
Old Feb 19, 2005 | 10:33 PM
mrbsponge's Avatar
so far from what i have seen and read, you want the wastegate to be the first thing to see boost obviously as a precaution and accuracy, thats why i used the compressor nipple, my gauge is off the back of the manifold
Old Feb 20, 2005 | 01:00 AM
PrettyLude's Avatar
Default Re: best place for boost gauge and wastergate hookup (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Get your gauge source at the intake manifold and the wastegate source right after the turbo, or after the intercooler and before the throttle body.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">so far from what i have seen and read, you want the wastegate to be the first thing to see boost obviously as a precaution and accuracy, thats why i used the compressor nipple, my gauge is off the back of the manifold</TD></TR></TABLE>
i would use the intake manifold for the pressure source for the gate, reason being you would want gate to see the actual psi your motor is getting, putting it at the compressor housing, you have to consider the pressure drop thru the cooler
Old Feb 20, 2005 | 11:27 AM
radioren's Avatar
Default Re: best place for boost gauge and wastergate hookup (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i would use the intake manifold for the pressure source for the gate, reason being you would want gate to see the actual psi your motor is getting, putting it at the compressor housing, you have to consider the pressure drop thru the cooler</TD></TR></TABLE>
thats what I was wondering. But since Im using such a low boost app would there be more than 1psi drop in boost?
Old Feb 20, 2005 | 05:03 PM
Mr_Bojangles's Avatar
bump
Old Feb 20, 2005 | 05:35 PM
PrettyLude's Avatar
the pressure drop from the cooler should be no more than 1.5 psi
Old Feb 20, 2005 | 07:31 PM
MooreBoost's Avatar
Default Re: (PrettyLude)
You do not want to tap at the manifold, it's complicated, but in essence it will cause slight compressor surge each time you let off the throttle.
Old Feb 20, 2005 | 09:20 PM
drift2004's Avatar
Default Re: (MooreBoost)
that is why u get a blow off valve
Old Feb 21, 2005 | 08:07 AM
MooreBoost's Avatar
Default Re: (drift2004)
The BOV doesn't matter in that situation, for a split second you BOV, throttle plate, and wastegate will all be closed, causing compressor surge.
Just tap before the throttle plate.
hondamonkey
Aug 6, 2007 07:02 PM
R6E6I6D
Nov 24, 2005 04:36 PM
Sport_Injected
Aug 29, 2004 04:28 PM
BlackB18CTeg
Nov 4, 2003 04:27 PM
