Mini Me HELP : crank pulley BOLT!
Old Feb 19, 2005 | 07:10 PM
thrty8street's Avatar
Default Mini Me HELP : crank pulley BOLT!
hey im doing my mini me and im trying to get the crank pulley bolt off to i can do the timing belt.
I cant get the crank pulley bolt off, i used my compressor which is 150psi and i got a bluepoint 1/2inch impact and an ingersol rand 1/2 impact and i couldnt get it off,
I also broke 2 craftsman 17inch sockets with a breaker bar.
help me out man
Old Feb 19, 2005 | 07:11 PM
Weapon_R's Avatar
Keep working at it.
I broke 3 1/2" extensions before I bought a 1" socket and extension. It's come...
Old Feb 19, 2005 | 07:16 PM
Kamin's Avatar
Default Re: (MickeyA)
4ft of pipe from home depot and jump on it.
Old Feb 19, 2005 | 07:17 PM
delslo93's Avatar
Default Re: Mini Me HELP : crank pulley BOLT! (thrty8street)
get a bigger air compressor....when i was doing mine we had a big compressor and big gun and gave it hell. It will eventually come good luck
rob...'s Avatar
it's a bitch but it'll come free.
Old Feb 19, 2005 | 07:23 PM
Default Re: Mini Me HELP : crank pulley BOLT! (delslo93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 &raquo;</TD></TR><TR><TD CLASS="quote">get a bigger air compressor....when i was doing mine we had a big compressor and big gun and gave it hell. It will eventually come good luck</TD></TR></TABLE>
damn how big of a compressor do i need to buy? i had just bought this one thinking it was enough, so it was a waste of money?
oh yea i had the car in 5th gear and had my little brother smash on the brakes to keep it from moving, anything else i could do?
oh yea this is a d15b7 block and the crank pulley is a little different then the z6 one
thanks for the replies
Old Feb 19, 2005 | 07:29 PM
egizzle8
Guest
Posts: n/a
5th gear, brakes, deep socket 17mm(no extensions) and a piece of tubing. The extensions allow twisting too much otherwise if you do have to use extensions put a floor jack underneath keep to it straight if your gonna use alot of them. Never really had a problem with them though and I don't use air tools ever since I don't own a compressor. Elbow grease works and alot of swearing does wonders!
Old Feb 19, 2005 | 08:00 PM
lkailburn's Avatar
i'd imagine some cans of pb blaster, shop solve, and wd-40 should be emptied on it lol
the one on my y8 block doesn't even need a deep socket to reach it, just the shorty one. so use the short one if you can, you get better leverage. unfortunately im going to have to do this aswell come spring for the exact reason your doing it. new timing belt with mini-me swap.
lillowek used a strap wrench to keep it in place.
http://www.jdmuniverse.com/for...32971
maybe give that a try
best of luck and let us know what works for ya
Old Feb 19, 2005 | 08:02 PM
Default Re: Mini Me HELP : crank pulley BOLT! (egizzle6)
here are some pics:
here is the old head off
d15b7 crank pulley ( the one I have)
VS
d16z6
that means i cant use this....
Old Feb 19, 2005 | 08:06 PM
komat's Avatar
get a impact socket
much stronger
PyroProblem's Avatar
Default Re: (lkailburn)
Keep the compressor and get yourself a 3/4" impact gun...They use them on Diesels and locamotives and big ****...They put out something like 1500 ft/lbs of torque or something crazy like that....
Theyre kinda pricey so your better off renting one from a tool place or something...That or find a diesel tech and rent it from him
Old Feb 19, 2005 | 08:12 PM
bpowa's Avatar
looks like u got rust.. use some lube leave it for 30 min.. and do not use an extension that long.. hech dont use an extension at all.. ,,, and use a 1/2 wrench for the sake of rust
Old Feb 19, 2005 | 08:15 PM
Default Re: Mini Me HELP : crank pulley BOLT! (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">Keep the compressor and get yourself a 3/4" impact gun...They use them on Diesels and locamotives and big ****...They put out something like 1500 ft/lbs of torque or something crazy like that....
Theyre kinda pricey so your better off renting one from a tool place or something...That or find a diesel tech and rent it from him </TD></TR></TABLE>
i have no idea where to find something like , but is my compressor strong enough for the bolt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">get a impact socket
much stronger</TD></TR></TABLE>
good idea ill get one tomarow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">i'd imagine some cans of pb blaster, shop solve, and wd-40 should be emptied on it lol
best of luck and let us know what works for ya</TD></TR></TABLE>
thanks for the link man my civic is the obd1 EG but the more info the better I just sprayed the bolt with some pb blaster, ill let it soak overnight and see what happens
Old Feb 19, 2005 | 08:16 PM
Default Re: (bpowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpowa &raquo;</TD></TR><TR><TD CLASS="quote">looks like u got rust.. use some lube leave it for 30 min.. and do not use an extension that long.. hech dont use an extension at all.. ,,, and use a 1/2 wrench for the sake of rust</TD></TR></TABLE>
how do i NOT use an extension??? just use a deep 17 ? but if i did that i wouldnt have much leverage since my car is on jack stands, should i raise the car up more or what should i do?
Old Feb 19, 2005 | 08:19 PM
Andres-eh2's Avatar
Go out and buy a torch. like $10 - 20, heat it up till the sucker is red and the compressor should work. Also, try jumping on the breaker bar while its on.
Old Feb 19, 2005 | 08:26 PM
komat's Avatar
Default Re: (Andres-eh2)
if you use an extention
use a jack to support the extention to make it straight
so you can use all your weight pushing down instead of holding it and pushing it down
Old Feb 20, 2005 | 04:30 PM
bpowa's Avatar
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">
how do i NOT use an extension??? just use a deep 17 ? but if i did that i wouldnt have much leverage since my car is on jack stands, should i raise the car up more or what should i do?</TD></TR></TABLE>
use jack stands lay on the ground and stomp on it. or you can do it from the engine bay if there is enough room (yank on it)
Old Feb 20, 2005 | 04:58 PM
Default Re: (bpowa)
thanks everyone for your help , I finaly was able to get it off. this is what i did:
- removed starter and put a large screwdriver in the flywheel teeth
- used the breaker bar without and extension
- sprayed pb blaster
that seemed to do the trick, thanks again for the help
Here is an update of my mini-me:
decided to take out my ac aswell:
Modified by thrty8street at 12:01 AM 2/21/2005
Old Feb 20, 2005 | 07:41 PM
bpowa's Avatar
np.. never use an extension,,, it takes the torque away..
no matter how tough the bolt there is away.. gotta get used to it..
Old Feb 20, 2005 | 07:52 PM
BauleyCivic's Avatar
Risky Business
Default Re: (bpowa)
Sweetness!
I'll have to check it out when its all running...good work
vaspeeder
Engine Management and Tuning
May 2, 2009 10:11 PM
prelude1897
Jul 11, 2006 03:11 PM
Yolandita
May 21, 2006 06:54 PM
93gsrcoupe
Sep 30, 2004 09:54 PM
ManinCamo
Jan 1, 2002 09:58 AM
