jdm climate control in a eg?
Old Feb 19, 2005 | 05:13 PM
jdmeg9's Avatar
Default jdm climate control in a eg?
why does everyone say that the jdm climate control will not work in a eg?
Old Feb 19, 2005 | 05:34 PM
rhdSiR's Avatar
Default Re: jdm climate control in a eg? (jdmeg9)
alot of stuff to do to get it to work properly....wiring, ducts, actuators...its not an easy bolt in 1,2,3 procedure...
Old Feb 19, 2005 | 05:41 PM
jdmeg9's Avatar
Default Re: jdm climate control in a eg? (rhdSiR)
i plugged it in and stuff the basic stuff works pretty much and the fan works. the hot and cold works because i don't have ac and the hot and cold just pretty much controls the radiator circulator
Old Feb 19, 2005 | 05:44 PM
GdmLaz's Avatar
hmmm im pretty sure is plug n play
Old Feb 19, 2005 | 05:47 PM
meccA's eg6's Avatar
Default Re: (Slammed92hbonN20)
most of what i read says that you just swap out the face to get the amber part....but that the harness's are different but i wouldn't know cause i haven't gotten mine yet
Old Feb 19, 2005 | 06:07 PM
rhdSiR's Avatar
Default Re: (meccA's eg6)
its not plug and play....JDM climate control has a temp scale in celcius, you set it to a certain temp and it will keep your car at that temp....usdm has the hot/cold blue/red line...
if you mean plug and play like it will install right, yes it will fit in there...it wont work properly though...if you dont have a/c (like alot of ppl here) it won't be much of a problem
Old Feb 20, 2005 | 04:34 AM
jdmeg9's Avatar
Default Re: (rhdSiR)
yeah i don't have ac so it just controls the heater core flow. everything else plugs right in. no extra harness plugs or anything
Old Feb 20, 2005 | 10:36 AM
rhdSiR's Avatar
Default Re: (jdmeg9)
yeah if you want it for just the jdm look, then it will work for you..
Old Feb 20, 2005 | 11:16 AM
jdmitr's Avatar
OK The JDM climate control for the EG6-EG9 are electronicly controlled and have several sensors inside and outside. The hot and cold are electronic (where the US is cable). The Best thing to do is change the face plate of the JDM one with the chassis of the US one.
IT is NOT plug and play!!!!
Old Feb 20, 2005 | 11:23 AM
90civichb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">why does everyone say that the jdm climate control will not work in a eg?</TD></TR></TABLE>
The JDM climate control IS plug and play in an EG.. That is the car it was removed from..
Now.. in an EH.. that is a different story..
Old Feb 20, 2005 | 12:29 PM
jdmeg9's Avatar
Default Re: jdm climate control in a eg? (90civichb)
yeah it fits right in. everyone thinks that when you say jdm climate control. that it is like a prelude or accord where it has a digital display for everything
Old Feb 20, 2005 | 12:41 PM
90civichb's Avatar
what i meant is "JDM climate control" would be an OEM piece in an EG civic.
Old Feb 20, 2005 | 01:52 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">yeah it fits right in. everyone thinks that when you say jdm climate control. that it is like a prelude or accord where it has a digital display for everything</TD></TR></TABLE>
are you saying that faceplate fits in? it does. now do u have the ENTIRE AUTO CLIMATE CONTROL system in there? like the accord and prelude AUTO CLIMATE CONTROL, the system monitors the interior temperature and sets the climate control settings (fan speed, direction ducts, and temp) automatically.
Old Feb 20, 2005 | 02:01 PM
rasinhell's Avatar
Default Re: jdm climate control in a eg? (dantastic)
Jdm eg6 climate control will not work on US eg. I was going to buy one until I realized that I needed a bunch of wires and then a weird disc shaped thingy.
Old Feb 20, 2005 | 02:35 PM
1992HB's Avatar
Default Re: jdm climate control in a eg? (The-Beast)
Yea, the jdm climate control won't work in the usdm eg because the usdm climate control is all mechinical and the jdm one is all electric. you can however change the face for the look.
Old Feb 21, 2005 | 11:48 AM
jdmitr's Avatar
Default Re: jdm climate control in a eg? (1992HB)
This is stupid! IT DOES NOT FIT THE USDM OR EVEN THE LOWER MODEL JDM CARS!!! It is NOT digital but it is all electric! It does physically fit the car, but it will NOT plug and play! It hooks up in the same way as the digital ones but has no display! I have swapped out the faces several time! The only way you could do this is with a electronicly controlled heater core, dash harness and all climate control sensors for a LHD!!!
Don't reply if you don't know! That is how you cost people time and money!!!
Old Oct 5, 2005 | 02:27 PM
WONG FRIED RICE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">i plugged it in and stuff the basic stuff works pretty much and the fan works. the hot and cold works because i don't have ac and the hot and cold just pretty much controls the radiator circulator</TD></TR></TABLE>
ur basically either lying, or you have a RHD EG
Old Oct 5, 2005 | 02:54 PM
philosofy1's Avatar
Default Re: jdm climate control in a eg? (jdmitr)
i would have to agree with jdmitr, the jdm eg climate control does phsically fit in the dash, but DOES NOT WORK (because its electric, and ours are manual) on u.s. 92-95 civics. if you dont believe it, go ahead and waste your time trying!
Old Oct 5, 2005 | 03:09 PM
kaiba's Avatar
Default Re: jdm climate control in a eg? (philosofy1)
Personaly, I think the JDM climate control looks ugly. I prefer the stock US.
Old Oct 5, 2005 | 07:40 PM
B20badboy's Avatar
Default Re: jdm climate control in a eg? (kaiba)
I have one USDM with a JDM face and the buttons are a little different.
Deadlock281
14
Dec 27, 2012 03:38 AM
JDM-EJ1
Oct 19, 2005 09:55 AM
beefjerky
Aug 26, 2005 03:45 PM
shai x boi racer
Apr 3, 2005 04:48 PM
