Radiator is steaming....??????
Old Feb 19, 2005 | 02:53 PM
tkHBseries's Avatar
Default Radiator is steaming....??????
I ran my car pretty hard about 2 days ago and blew the radiator cap off my radiator. After replacing the cap the radiator is steaming from the spines or (ribs) all the time, do you fellaz think the Radiator is a blown or just the residue from the coolant steaming off!!!!! I checked all hoses and seams, they all seem dry and sealed! Thanks for any input!
Old Feb 19, 2005 | 03:22 PM
Kamin's Avatar
Default Re: Radiator is steaming....?????? (tkHBseries)
did you refill the radiator?
is your temprature going up?
Old Feb 19, 2005 | 05:13 PM
ENDGAME's Avatar
you more than likely just pushed to hard on a small weak spot on the radiator and it is just a pin hole leaking.... try some radiator sealent.... like barsleak
Old Feb 19, 2005 | 05:17 PM
Kamin's Avatar
Default Re: Radiator is steaming....?????? (ENDGAME)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENDGAME &raquo;</TD></TR><TR><TD CLASS="quote">you more than likely just pushed to hard on a small weak spot on the radiator and it is just a pin hole leaking.... try some radiator sealent.... like barsleak</TD></TR></TABLE>
BAD idea
fix the problem, dont put a bandaid on it
remember that sealing **** circulates throughout your entire cooling system
heater core, water pump, etc.
Old Feb 19, 2005 | 06:48 PM
tkHBseries's Avatar
Default Re: Radiator is steaming....?????? (Kamin)
No i drive the car around for about 10 mins and let it sit @ idle for another 10 mins. temp seems fine
vxtirent08
Mar 20, 2008 10:36 AM
kingpen
Oct 31, 2002 12:19 PM
BluLuder
Jul 29, 2002 11:29 AM
EGh22aEG
Jan 9, 2002 06:37 PM
