Arias wrist pin locks
I was just wondering how the hell these things go in. They are not normal snap rings that I'm use to... with the two holes that you can use snap wring pliers on.
Thanks in advance for any help
I just got done doing this, stretch the rings a little so they look like coil springs. Put the end in towards the bottom first, then push the rings down into the pin bore as much as possible, then take a ballpoint pen and "trace" around the circumference of the circle until it pops into the groove. Also if you apply a twisting force you can make the clip flex enough to decrease the diameter, and then it will go in easier.
98Luder
17
Dec 18, 2012 02:07 AM
stackz
Feb 21, 2005 01:48 PM
