B16 swap, high idle NEED HELP
Old Feb 19, 2005 | 06:20 AM
B1692LS's Avatar
Default B16 swap, high idle NEED HELP
Just swapped in a JDM B16 second gen into my 92 teg. All is good, it isnt throwing any codes at all (well Code 20 for ELD) but anyway, I'm revving @ 3 grand and theres a bit of a whining sound. What could this be ? I plugged in my old B18 ECU, and the idle came down a bit but.....
My thermostat wasnt moving so I checked the top rad hose, hot...bottom, cold. So my thermostat wasnt opening, I am going to fix that today. Would this be causing it to rev so high ? I wouldnt think.
Need HELP and fast.
Old Feb 19, 2005 | 12:07 PM
PrettyLude's Avatar
is it revving right when you start it?
if it is, check ur throttle cable
Old Feb 19, 2005 | 01:56 PM
notstock93's Avatar
Default Re: (PrettyLude)
spray some carb/choke cleaner on the engine to check for leaks, and check the idle screw and all that jazz.
Also- how much did the idle drop when you put in the LS ECU?
wicca_eagle
10
Jul 20, 2005 12:39 AM
B1692LS
Feb 22, 2005 08:58 PM
wpgcivic
May 19, 2004 06:02 PM
Mentat Ghola
Apr 6, 2004 03:15 PM
g2style
Feb 3, 2003 12:14 PM
