B16 High Idle. HELP FAST
Old Feb 19, 2005 | 07:12 AM
B1692LS's Avatar
Default B16 High Idle. HELP FAST
I posted in the tech forum too. I need help. The search button is unavailbale right now.
Just swapped in a JDM B16 second gen into my 92 teg. All is good, it isnt throwing any codes at all (well Code 20 for ELD) but anyway, I'm revving @ 3 grand and theres a bit of a whining sound. What could this be ? I plugged in my old B18 ECU, and the idle came down a bit but.....
My thermostat wasnt moving so I checked the top rad hose, hot...bottom, cold. So my thermostat wasnt opening, I am going to fix that today. Would this be causing it to rev so high ? I wouldnt think.
Need HELP and fast.
Old Feb 19, 2005 | 08:07 AM
B1692LS's Avatar
Default Re: B16 High Idle. HELP FAST (B1692LS)
Anyone ? I'm in a jam
Old Feb 19, 2005 | 08:37 AM
B1692LS's Avatar
Default Re: B16 High Idle. HELP FAST (Palmy Blue)
Wheres that located ?
Old Feb 19, 2005 | 08:43 AM
andrew dc's Avatar
the grey thing above #8 (flat head)
Old Feb 19, 2005 | 10:49 AM
B1692LS's Avatar
Default Re: B16 High Idle. HELP FAST (andrew ef)
I think that the #8 you have listed doesnt have a place for a flathead to go in. I may be wrong I havent been down to look yet.
What about the TPS #9. If I loosen the screws and move that up or down, will that adjust my idle ?
Its JDM btw
Old Feb 19, 2005 | 10:53 AM
andrew dc's Avatar
I said ABOVE #8
Old Feb 19, 2005 | 11:40 AM
NightmareApex's Avatar
Since you really have no clue whats what or wheres what, id take the car to a shop, and have them tightne the motor up for ya. When ever you do a swap there are always going to be a few bugs to fix, your problem could be that the tps sensor is not on correctly which will cause the motor to rev really high, another thing is the idl steady, or does it fluctuate.
Old Feb 19, 2005 | 03:27 PM
aspec101's Avatar
CHECK FOR VACUUM LEAKS! This is the number one cause for high idle after a swap forgetting to connect a vacuum hose or cracked hoses. do not use the idle adjust on the throttle body this will just attempt to mask you real problem. This is only to be used for fine tune adjusting.
Old Feb 22, 2005 | 08:55 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: B16 High Idle. HELP FAST (vaperformance)
#8 is the screw above the throttle body, had that same prob, just tone it down a bit using ur tach....
Old Feb 22, 2005 | 08:58 PM
jizno's Avatar
adjust the idle screw and if you just did a swap there could be coolant bubbles and other goodies for ya to sort out
WideBodyFEELZ
19
Apr 18, 2017 09:16 PM
Deej23
Mar 14, 2012 07:31 PM
h22_crx
May 6, 2008 11:31 PM
B1692LS
Feb 19, 2005 01:56 PM
