Stripped Flywheel Bolt..
Old Feb 18, 2005 | 07:13 PM
all motor b20b's Avatar
Default Stripped Flywheel Bolt..
What do I do to get it off. I already tried to extract it, but it still wont come out.
Old Feb 18, 2005 | 10:06 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Stripped Flywheel Bolt.. (all motor b20b)
if you have to drill it out, i have a tap for the threads...it's hard to find.
Old Feb 18, 2005 | 11:21 PM
Eddiebx's Avatar
go get some stripped nut remover sockets from sears, those will take her out
Old Feb 19, 2005 | 12:00 AM
boosted k20's Avatar
Default Re: (Eddiebx)
i stripped a few of those bolts. i HATE those bolts. the worst ever!!!! they're not deep at all so u cant really get a good grip on it with a 12 point socket. i need to put alot of ur body wieght into the bolt so it wont slip.
this is what i did. u weld another bolt onto the stripped bolt and then turn the welded bolt to unscrew it. works all the time
spidermancivic
Aug 11, 2007 08:17 AM
all motor b20b
Feb 22, 2005 01:05 AM
sidious141
Aug 27, 2004 07:13 PM
Layziebtnh055
May 14, 2004 06:42 AM
giooooo
Feb 6, 2003 08:25 PM
