Just changed MTF. some questions/
Old Feb 18, 2005 | 12:25 PM
RicharDC4's Avatar
Default Just changed MTF. some questions/
after about 2 months of notchy shifting and a lot of grinding due to low ammounts of tranny fluid, i finally got time to change it.
i heard a lot of people say when they have notchy shifting, after the fluid change, it feel much better. but when i changed my tranny fluid, it still feels notchy. can this be problems of worn out syncros?
another question i have is that i didnt torqe down the bolts to the correct specs. i just tightened them down till i couldnt anymore. is this a problem?
Thanks
Old Feb 18, 2005 | 12:37 PM
CNSK's Avatar
Default Re: Just changed MTF. some questions/ (RicharDC4)
try the gm synchromesh.....
Old Feb 18, 2005 | 01:07 PM
tnord's Avatar
Default Re: Just changed MTF. some questions/ (CNSK)
tighten what bolts down?
Old Feb 18, 2005 | 01:13 PM
RicharDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">try the gm synchromesh.....</TD></TR></TABLE>
well i used pennzoil synchromesh, heard it was the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">tighten what bolts down?
the drain and fill bolts.
Old Feb 18, 2005 | 02:52 PM
9000rpms's Avatar
You'll be fine...
Old Feb 18, 2005 | 04:36 PM
AlphaQup's Avatar
are you running any type of short shifter? Does it grind into gear while shifting @ high RPM's?
If you have a Short shifter, that can be the problem, because they usually feel more knotchy than stock.
If it's the other problem I stated above, or both... then it's your synchros gone/going bad.
Old Feb 19, 2005 | 11:27 PM
RicharDC4's Avatar
Default Re: Just changed MTF. some questions/ (AlphaQup)
its not really any grinding, its just not as smooth as it was a year ago.
Old Feb 19, 2005 | 11:28 PM
NightRiderS2K's Avatar
In-N-Out Burger
Wear and tear?
Old Feb 20, 2005 | 09:46 AM
slowman's Avatar
I took way too long
Default Re: Just changed MTF. some questions/ (NightRider-gsR)
I think you need like 500 miles or something before you can tell the benefits of the Syncromesh if you will feel any at all.
eyeballs
Sep 16, 2007 06:44 PM
TopNotchR
Sep 24, 2004 06:50 PM
SpoolnG2
Jul 29, 2004 06:15 AM
danny98r
Jul 23, 2004 07:56 AM
ooooitswilson
18
Sep 15, 2003 02:09 PM
