new SI seats bolt right into a 91 CRX HF ?
Old Feb 17, 2005 | 12:22 PM
Pesh's Avatar
Default new SI seats bolt right into a 91 CRX HF ?
I want to replace my CRX seats with the new SI seats and im not sure if the bolt pattern is the same, can anyone confirm this...
I know that may be pricey so shy of racing buckets what other options are out there.
Thanks!!
Old Feb 17, 2005 | 12:49 PM
turboLSef's Avatar
Default Re: new SI seats bolt right into a 91 CRX HF ? (Pesh)
they prolly wont bolt up
https://honda-tech.com/zerothread?id=988203
but you can always do a pan swap....
https://honda-tech.com/zerothread?id=347548
hope this is help
Old Feb 17, 2005 | 01:49 PM
C_REX's Avatar
Default Re: new SI seats bolt right into a 91 CRX HF ? (turboLSef)
I don't think it will look right if it does fit, cause its too high up.
Old Feb 17, 2005 | 02:53 PM
JapJunkie's Avatar
Default Re: new SI seats bolt right into a 91 CRX HF ? (C_REX)
hmm i did 90-91 hb si seats in my 88 hb. I like them a lot.
heres my write-up
https://honda-tech.com/zerothread?id=1062869
Old Feb 17, 2005 | 02:57 PM
PHOBIA's Avatar
they will sit really high up,hell my cloth gsr seats drive me nutz because they sit to high and the ep3 seats are way worse.and no they wont bolt up.almost every other civis uses other bolt patterns so why would they fit? its a pretty simple fix. go to a hard ware store and buy a piece of flat steel for like $5.00 and cut the size you need lay it accross the bottom of the rails and drill ne holes. then mount that to the old location.
Old Feb 17, 2005 | 03:54 PM
JapJunkie's Avatar
Default Re: (PHOBIA)
I dont get how CRX Si seats will sit high in a CRX???? I believe this is false. If he comes up on 90-91 CRX Si not HB Si, they will bolt up.
Old Feb 17, 2005 | 06:16 PM
PHOBIA's Avatar
wait wait are you talking about putting ep3 seats in your car or newer crx seats? i was under the inpresion you meant the ep3's
Old Feb 17, 2005 | 06:20 PM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">wait wait are you talking about putting ep3 seats in your car or newer crx seats? i was under the inpresion you meant the ep3's</TD></TR></TABLE>
ohh okay its my bad. Yup i fuked up, the dude asked for "new Si" seats. Then nevermind for my thread link.
NOOLCRAFT
Feb 21, 2010 12:45 AM
Youlose1305
Sep 2, 2006 08:49 AM
Spec911
May 29, 2006 12:45 AM
Red_Si
Dec 14, 2003 02:43 PM
CivicHB91
Nov 11, 2002 09:58 PM
