Tight U-bend
Old Feb 17, 2005 | 06:17 AM
DMax013's Avatar
Default Tight U-bend
nearing the finish of my turbo setup and i have a problem connecting the IC to the IC pipe on the turbo side... what i need is a 2.5 or 2.25..forget which one..none the less, peice of pipe in a u-bend form but its such a tight radius that it cant be done. local exhaust shops tell me it can be bent no more than 30 degrees n e how. what i was thinking is taking 2 90 degree elbows, sawing them off at the end of the bend so that they both remain 90 degrees and then welding the 2 together so that theres about an inch and a half between the 2. would this work? i mean it seems like my only option at this point.
Old Feb 17, 2005 | 06:30 AM
delslow94's Avatar
Default Re: Tight U-bend (DMax013)
use a lobster back bend. make small angle cuts on at the location of the radius but not fully through the pipe then bend the pipe towards the bend and weld all the seems together. search google and you will find pics
Old Feb 17, 2005 | 07:54 AM
Ekasey's Avatar
Try looking over what radius bends we have availables we offer some pretty tight stuff
you can figure the center to center distance (distance from center of one leg to the cente rof the other) by doubling* the centerline radius given here in the part #
UB-200-30-18-304 this would be a 6" center to center distance
Old Feb 17, 2005 | 08:05 AM
DMax013's Avatar
Default Re: Tight U-bend (eLusive ek4)
even tighter than that..if i were to guess without being at my car id say center to center of 2.5 inch pipe.. 4 inches tops.. its mighty tight but only way to be done
Old Feb 17, 2005 | 11:04 AM
BmCRace.com's Avatar
try this guy on ebay, tight bends and has anything a downpipe maker or charge line maker could want.
http://stores.ebay.com/VertexN...QtZkm
Old Feb 17, 2005 | 11:25 AM
Ekasey's Avatar
Default Re: Tight U-bend (BmCRace.com)
LOL that guy jacked our header and used it for his graphics!
Old Feb 17, 2005 | 12:42 PM
JDcompman's Avatar
Take a look at this thread...
https://honda-tech.com/zerothread?id=731051
I think this is what your looking for and gives you really tight angles. It's called a "donut pipe".
Jason
Old Feb 17, 2005 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL that guy jacked our header and used it for his graphics!</TD></TR></TABLE>
even if he did he still has good bends for a good price.
Old Feb 17, 2005 | 06:36 PM
tony1's Avatar
LOL, I thought that header looked familiar! It even looks light in the pics!
Old Feb 17, 2005 | 07:34 PM
mrvoodoo's Avatar
Default Re: Tight U-bend (tony1)
I can bend 2.5 on 2.5 stainless 304. Not cheap though. I do 1.625, 2 and 2.5 on 1D.
Old Feb 18, 2005 | 10:18 PM
Full-Race Javier's Avatar
Default Re: Tight U-bend (titanperf)
you can also run a tight radius 90 deg silicon coupler if you cant find a tight enough bend.
tight radii 90 deg silicon couplers
if you go this route, invest in some heavy duty constant torque t bolt clamps too. usually, the more couplers you have, the greater chance you have of "loosing" charge pipes
b18cya94
Welding / Fabrication
24
Mar 26, 2013 05:41 AM
90Rexx
May 18, 2010 02:27 PM
mikeycivic
Dec 7, 2009 01:34 PM
ChillOutWayne
May 14, 2004 08:45 AM
SiRGodfather
Jul 23, 2003 11:27 AM
