STR Block Saver ???????
Old Feb 16, 2005 | 09:19 PM
whytTypeR's Avatar
Default STR Block Saver ???????
Is the STR block saver good for all motor,or just for boosting or both???? what does it do????
Old Feb 16, 2005 | 09:37 PM
whytTypeR's Avatar
Default Re: STR Block Saver ??????? (whytTypeR)
anybody somebody
Old Feb 17, 2005 | 07:50 PM
whytTypeR's Avatar
can somebody help
Old Feb 17, 2005 | 07:51 PM
Haleiwa-Brando's Avatar
Check the website.
Old Feb 17, 2005 | 08:07 PM
white rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whytTypeR &raquo;</TD></TR><TR><TD CLASS="quote"> what does it do????</TD></TR></TABLE>
I'm gonna take a wild stab at this. I believe that it goes around the sleeves to prevent slippage. That's my guess.
Old Feb 17, 2005 | 08:22 PM
vtec.dc2's Avatar
Default Re: STR Block Saver ??????? (white rocket)
its there to prevent from movement, expanding? i don't think it wil stop from sinking but i never looked into it much. i know theres a good chance of not getting it to work right, leading to more problems, but if installed right, will do the job for higher hp applications. but i see it not very usefull because you're likely to crack a sleeve if running that much hp and that hp would have to be from turbo, and more than average hp level. even with sleeveing theres a good chance of not getting the job done right, but it may come necessary if you're runnig for lots hp.
to your original question, i wouldn't bother with block guards for n/a setup.
Old Feb 17, 2005 | 08:29 PM
SecretAgent's Avatar
works really well for fairly low boost setups &lt;15psi and for high revving all motor setups. but to install it properly, you need to have the out-or-round checked on the cylinder after you install it. we've put in a couple that have distorted the bore enough to cause too much blow-by, causing us to have to get the block honed.
92redhatch
Mar 5, 2006 05:52 PM
boostedcivicsir
Nov 26, 2005 08:44 PM
londa hover
Aug 24, 2004 08:52 PM
turbodGSR
Apr 27, 2003 09:00 AM
allmotorls95
Apr 21, 2003 10:38 PM
