All motor b18c top end lean out
Old Feb 16, 2005 | 07:51 AM
b18c1Monster's Avatar
Default All motor b18c top end lean out
I have been running the b18c in my eg hatch now for about 3 months. All i have done is a walbro 355lph fuel pump, cold air intake, and b&m regulator. At high rpms the air fuel gauge goes lean and I kind of feel the car hesitate a little. And every once and a while if im cruising the car would kind of hesitate for a couple of seconds and then stop. Any ideas?
Old Feb 16, 2005 | 07:52 AM
Luserkid's Avatar
Default Re: All motor b18c top end lean out (b18c1Monster)
You have a 355lph fuel pump?!? You mean 255 right? And why?
Do you have wideband? How do you know your going lean?
Go back to stock fuel pump or get it tuned.
Old Feb 16, 2005 | 05:57 PM
yeah i meant 255lph. Im using the air fuel gauge.
Old Feb 16, 2005 | 06:03 PM
SOHCD16y8's Avatar
reg O2 sensor or wideband?
Old Feb 16, 2005 | 07:54 PM
Default Re: (SOHCD16y8)
regular o2
Old Feb 16, 2005 | 08:00 PM
tonis56's Avatar
Default Re:
since the stock o2 sensor only sends a 0-1v signal to the ecu and the wideband would send a 0-5v signal, the stock sensor doesn't have the capability to tell the computer if the mixture is rich or lean. it just compensates for the numbers that its given.
Cliff notes: wideband= accurate.
Stock 0-1v sensor= not accurate for tuning.
Old Feb 16, 2005 | 08:02 PM
SOHCD16y8's Avatar
yeah the stock sensor only gives a general idea, if you were truly running dangerously lean you would throw a code
Old Feb 17, 2005 | 05:57 AM
but sometimes if im flying on the highway it will throw a check engine but if I turn the car off and then start it back up it will go away.
Old Feb 17, 2005 | 06:07 AM
t0p_sh0tta's Avatar
Default Re: (b18c1Monster)
have you ever checked the code?
Old Feb 17, 2005 | 06:59 AM
Default Re: (t0p_sh0tta)
by the time I checked the code it was cleared
Old Feb 17, 2005 | 07:09 AM
xTravBx's Avatar
That doesnt make sense. They don't clear themselves.
Do you know how to check codes?
It sounds like your O2 sensor isn't working properly.
Old Feb 17, 2005 | 08:49 AM
CHEETAH's Avatar
couple things ... b&m can cause this, noticed it quite a few times on customer cars.
second, don;t discount your standard O2 readings, they are fairly acurate in the 14.7:1 stoic range ... so if its reading in that range then yes its lean.
greg
Old Feb 17, 2005 | 12:16 PM
projectegr's Avatar
Default asdf
Couple of things. First, the code is not cleared, it just isnt throwing the CEL. Most likely the knock sensor. This doesn't necessarily mean the motor is knocking, the sensor could be bad. If it is not the knock sensor, it could be the o2 sensor. Typically the o2 sensor will throw the cel within a few minutes after the engine is turned over. I've driven 500 miles before without the cel coming on for the knock sensor, but when I jump the ecu, it reads code 23.
Basically, loop the ecu, and read the cel. It will still put out a number if what is happening you are saying is true.
Second, depending on what a/f range you are in (14-15:1) your stock o2 sensor is accurate enough. When TUNING you will definately want a wideband.
Old Feb 17, 2005 | 06:14 PM
Default Re: asdf (projectegr)
I jumped the ecu and the check engine just stays on while the jumper is in. But if its running lean I was thinking it was a faulty fuel pump.I have a rev hard kit that I will be installing soon and I just want everything to be right before I install it. I ordered a str fuel rail,RC440s,ARp headstuds, and a ac blockgaurd.
Old Feb 17, 2005 | 07:14 PM
Ninja Mike's Avatar
Default Re: asdf (b18c1Monster)
So during a tune, one should use a wideband o2 sensor to see optimal results. But, after the tune is it safe to put back the stock o2 for daily driving and longetivity?
Old Feb 17, 2005 | 08:06 PM
Default Re: asdf (SleepEMike)
so how much can I pick one up for?
bboysake
Aug 23, 2006 02:04 PM
auto moto
Dec 28, 2005 05:45 PM
Stew Pidasso
Nov 18, 2003 05:27 AM
_Shadow_
Dec 21, 2001 06:01 AM
tr4il
Nov 24, 2001 09:46 PM
