Air/Fuel Meter...much more accurate???
New User
Hey I've been reading up on A/F meters and heard that the autometer A/f guage is innacurate with only 10 leds.
I came across this new meter and it looks pretty interesting. http://www.nitrouskits.com/search_re...btnSearch.y=12
The link above is where I found it. Looks like it would be great for tuning, to get the right amounts of fuel.
Well what do you think?? Its more expensive but alot more accurate.
Re: Air/Fuel Meter...much more accurate??? (_Shadow_)
The stock O2 sensor is not accurate because it does not compensate for exhaust temperature. The inaccuracy of the system does not lie in the gauge.
Dustin
Dustin
New User
Re: Air/Fuel Meter...much more accurate??? (dustin)
so your saying a A/f guage is useless with the stock O2 sensor?
Will using a high quality EGT guage be better? I need to monitor my turbo system and only have a boost guage at the moment.
you need to get an air/fuel meter and a wide band o2 sensor... but if your turbo.. just get an EGT, seems more of an indicator of running rich or lean...
Get an EGT, much more accurate. Around here, we can A/F gauges, "Fast and Furious" - looks cool, but doesn't do that much.
New User
Might as well be 40 or even 80 leds if it is hooked to the stock O2 sensor.
Dustin
Dustin
Re: Air/Fuel Meter...much more accurate??? (GSRacer)
can i buy a better o2 sensor, instead of using the factory one? and use it w/ an airfuel meter?
