Wheel Offset for Type R
Old Jan 17, 2002 | 05:56 PM
advan24r's Avatar
Default Wheel Offset for Type R
What is the wheel offset for a 98 Type R?? I have a set of 17"s and would like to know what it is...17x??? and what other cars would have a 5 lug pattern that would fit type R wheels and/or other aftermarket wheels
[Modified by advan24r, 7:00 PM 1/17/2002]
Old Jan 17, 2002 | 05:57 PM
forksports's Avatar
Default Re: Wheel Offset for Type R (advan24r)
I believe its +45
Old Jan 17, 2002 | 05:59 PM
sgT's Avatar
sgT
Default Re: Wheel Offset for Type R (forksports)
Try 50
Old Jan 18, 2002 | 01:43 AM
DutchITR1689's Avatar
Default Re: Wheel Offset for Type R (sgT)
Then, someone tell me why everyone is putting +45 mm offset aftermarket rims (16 or 17") on the ITR and not just 50mm like stock.
Old Jan 18, 2002 | 02:12 AM
austrian type-R's Avatar
Default Re: Wheel Offset for Type R (EuroITR1689)
cause you the most don´t have 6.5 wideness, they use 7 or 7.5, therefore they chose 40 or 35 offset
Old Jan 18, 2002 | 02:54 AM
Default Re: Wheel Offset for Type R (austrian ITR)
How about the scrub radius. It should remain zero, right? Or at least same as stock. In that case you need to keep the offset the same....
http://home1.gte.net/macross/offsetFAQ.html
Old Jan 18, 2002 | 04:05 AM
aklucsarits's Avatar
New User
The Prelude, TL, CL, V6 Accord, and DSMs all use the 5x114 bolt pattern with a compararble offset (+55 to +45mm offset). I'm sure there are other cars too, but those are the ones that come to mind....
Andrew
Old Jan 18, 2002 | 04:19 AM
R-Adrenaline's Avatar
New User
Fuminsho should know the answer to this question.
jhamlett5
Jan 28, 2012 03:30 AM
ZXRider
May 1, 2007 01:25 PM
JeffS
Mar 13, 2003 05:24 AM
trahsub
Nov 22, 2002 11:35 PM
grngsr01
Oct 7, 2002 02:59 PM
