Wheel size and offset
Old Oct 6, 2002 | 08:00 AM
grngsr01's Avatar
Default Wheel size and offset
I am ordering wheels and tires (17's w/Toyo FZ4 205/40/17) later today and I just want to make sure of a couple things...
Lug Pattern: 4 X 100
Offset: 40 - 45
Is this the lug pattern for a 01 gsr off and what is the most common offset people use. The car is currently lowered with the eibach pro kit but might put hr sports on for a lower height, so what would the best offset be?
Is there much variance in weight between companys. The wheels I am looking for a most likely going to be a seven star by either konig, katana, enkei, exel, giovanna. What are good brands?
[Modified by grngsr01, 12:02 PM 10/6/2002]
Old Oct 6, 2002 | 10:22 AM
Ohlias's Avatar
Default Re: Wheel size and offset (grngsr01)
I think with a 17" wheel you will want a +45 offset. I think +40 would be cutting it too close. Especially if you loweer more. Wait till someone else chimes in though, I'm no expert....
Old Oct 6, 2002 | 10:25 AM
Brandon Chun's Avatar
Bolt pattern is right, so is the offset. 42 is supposed to be best but 40 is common.
Depends on the wheel I suppose. If you're worried about weight why are you going with a 17 haha j/k
Old Oct 6, 2002 | 02:37 PM
grngsr01's Avatar
Default Re: Wheel size and offset (Brandon Chun)
That is a real good point. So you think 40 instead of 45, but 42 is the best. Right now it is lowered 1.3" all around.
Old Oct 6, 2002 | 08:01 PM
grngsr01's Avatar
Old Oct 7, 2002 | 02:59 PM
grngsr01's Avatar
Up we go...
dt98gsr
Honda Civic (2006 - 2015)
35
Mar 10, 2008 12:59 PM
wytiak3
Jan 4, 2006 09:47 AM
JoeyBallzSI
Oct 20, 2003 03:04 PM
NoLipRacen
Feb 22, 2003 06:11 AM
trahsub
Nov 22, 2002 11:35 PM
