how do install wheel bearings
Old Feb 15, 2005 | 02:46 PM
yung98gsr's Avatar
Default how do install wheel bearings
I think my wheel bearing on the front passenger side is going bad. When I turn left it makes a droning noise. I have had a wheel bearing go bad in my 88 integra and it cost $250 to replace. I was wondering if it is possible to do it yourself. Are the fronts harder or easier than the rears to replace? Do I need to replace both sides up front or just the one going bad? thanks.
Old Feb 15, 2005 | 03:08 PM
Dan GSR's Avatar
Default Re: how do install wheel bearings (yung98gsr)
https://honda-tech.com/zerothread?id=720159
requires a press, something that most ppl don't have at their house
<--- this nut has a 20 ton press
Old Feb 15, 2005 | 03:14 PM
strikeback03's Avatar
gonna need access to a press, have to press the hub out of the bearing, the bearing out of the knuckle, probably press the inner race of the bearing off the hub; then press a new bearing in and press the hub into the bearing. The rears are much easier.
Old Feb 18, 2005 | 09:10 AM
yung98gsr's Avatar
Default Re: how do install wheel bearings (strikeback03)
So I am guessing that I can't do it myself, so how much would it cost to get it fixed? Do I need both sides replaced or just the damaged side. If I don't take care of this wheel bearing soon will it mess anything else up like warp your brakes or something. thanks.
Old Feb 18, 2005 | 09:28 AM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yung98gsr &raquo;</TD></TR><TR><TD CLASS="quote">So I am guessing that I can't do it myself, so how much would it cost to get it fixed?</TD></TR></TABLE>
I don't know how mechanically inclined you are, but you could just pull the knuckle and then have the bearings taken out and put in for like $30 at a shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yung98gsr &raquo;</TD></TR><TR><TD CLASS="quote"> Do I need both sides replaced or just the damaged side. </TD></TR></TABLE>
I would definately do both sides. The other side could go at any time because they have the same mileage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yung98gsr &raquo;</TD></TR><TR><TD CLASS="quote"> If I don't take care of this wheel bearing soon will it mess anything else up like warp your brakes or something. thanks.</TD></TR></TABLE>
YES! Worst case your wheel could come off or lock up. I rode on mine for about an hour after it started making noise and when I jacked the car up the rim teetered side to side about an inch. Not good. This is not something to mess with.
RacerTim
Sep 10, 2010 05:44 PM
petergriffen
Aug 11, 2006 08:44 PM
FakeJDMEF8
18
Nov 22, 2005 08:13 PM
pcorad
Nov 7, 2001 08:41 AM
