ABS problems
Old Feb 17, 2005 | 06:56 AM
mattL's Avatar
Default ABS problems
Hi guys, recently my ABS has been acting up. the symptoms basically are that when i turn on the car when its cold (in the morning) the ABS works the entire time the car is on, as soon as i turn of the car and restart it the ABS light comes on, there is no CEL. what are the possibilities? my brake fluid is full pads are fine. thanks
Old Feb 17, 2005 | 07:42 AM
qcktegls's Avatar
Default Re: ABS problems (mattL)
do u mean the light stays on the entire time until u restart the car when its warmed up? when u start the car the light should come on and then go off in about 5 seconds
Old Feb 17, 2005 | 08:16 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattL &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, recently my ABS has been acting up. the symptoms basically are that when i turn on the car when its cold (in the morning) the ABS works the entire time the car is on, as soon as i turn of the car and restart it the ABS light comes on, there is no CEL. what are the possibilities? my brake fluid is full pads are fine. thanks </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=978933
* This thread is stickied at the top. Also if you did a search on ABS you would have found your answer.
Old Feb 17, 2005 | 07:27 PM
mattL's Avatar
Default Re: ABS problems (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
* This thread is stickied at the top. Also if you did a search on ABS you would have found your answer.</TD></TR></TABLE>
please re-read my post where i stated there was no CEL, i also did do a search on ABS but didnt find a situation like mine.
NO the light does not stay on the first time i start the car, it is ONLY once i turn it off and then restart it that the light stays on and the ABS does not work. thanks
Old Feb 18, 2005 | 09:29 AM
mattL's Avatar
DC231_01
Jun 26, 2006 08:37 PM
1boostedcivic
Jun 19, 2005 04:30 PM
mikester_91
Dec 21, 2004 06:25 PM
jdmlude_dude
Mar 16, 2004 06:01 PM
aLmoSt-vtec
Jul 26, 2001 09:29 AM
