swapping a jdm b16 into a 92-95 civic coupe
Old Feb 15, 2005 | 09:54 AM
boostin1cam's Avatar
Default swapping a jdm b16 into a 92-95 civic coupe
what's the difference between swapping a jdm b16 into my car than a usdm b16? like what would i have to do to put the jdm one in that i wouldn't have to do with the usdm one. thanks guys
Old Feb 15, 2005 | 10:01 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: swapping a jdm b16 into a 92-95 civic coupe (93civcoupe)
You would have less to deal with installing the JDM one. It bolts in and you add three wires, (assuming its a DX), VTEC, VTEC Oil Pres, and Knock. Thats it. You would eliminate your EVAP system. If you went USDM you would have to get an ODB1 out of a Del Sol to be a true bolt in swap. Otherwise your using one out of a 99+ Si which is ODBII, and you will have to use a jumper harness to bring it to ODBI.
alscrx
Oct 23, 2009 08:14 PM
graveltravel
Oct 12, 2005 08:02 PM
Spoon DelSol
41
Mar 8, 2005 06:53 PM
anothersickhatch
Aug 14, 2004 06:58 AM
