threw a code 4
Old Feb 15, 2005 | 09:40 AM
socki18's Avatar
Default threw a code 4
well i did a search on "code 4" and i got nothing. i just did a b16a swap (obd1) into my 98 ex (OBD2). now its throwing a code 4-crank position sensor. has anyone else had this problem?
any suggestions on a fix?
Old Feb 15, 2005 | 11:49 AM
ryanplayjoint's Avatar
Default Re: threw a code 4 (socki18)
the obd-1 crank position sensor is in the distributor and the obd-2 sensor is on the front (timing belt side) of the block. The obd-2 sensor is a two wire magnetic pickup that when combined with a toothed wheel give an output voltage back to the ecu/pcm. The questions I have for you is what ecu/pcm are you using and what wiring harness are you using? The reason I ask is that you might be using a obd-2 wiring harness that does not have the wiring for a crank sensor that is in the distributor because that sensor is located on the side of the block.
Old Feb 15, 2005 | 11:37 PM
PrettyLude's Avatar
any update on this?
Old Feb 16, 2005 | 12:47 AM
ekb16's Avatar
how would you go about wireing the cps with a OBD2 dizzy??
sikcrx80
May 1, 2023 05:16 PM
BradEK9
May 14, 2014 05:50 PM
joshd_bh
Sep 5, 2012 08:14 PM
Rat_Bear
Jan 29, 2009 08:01 PM
Flamenco-T
Sep 8, 2002 12:05 PM
