how do u check for an exhaust leak?
Old Feb 15, 2005 | 01:02 AM
boosted ek's Avatar
Default how do u check for an exhaust leak?
i think i have an exhaust leak but can't figure out where it's coming from. any suggestion on how to check?
Old Feb 15, 2005 | 01:11 AM
eg6sir-s's Avatar
Default Re: how do u check for an exhaust leak? (boosted ek)
put your car on jack stands(all 4) leave your car running and run your hand from one end of the piping without touching the pipes and locate the leak.
Old Feb 15, 2005 | 01:25 AM
gumbii's Avatar
usually you could hear it...
Old Feb 15, 2005 | 01:45 AM
boosted ek's Avatar
Default Re: (gumbii)
just to make sure, exhaust leak with cause a rattle/stutter sound, right?
Old Feb 15, 2005 | 02:00 AM
gumbii's Avatar
not really... that could be that you have a loose heat shield, or a bolt/screw stuck... in there... or sometimes when your catalyst converter is really jacked up, it will sound like it has really course sand inside... it could be alot of things... a leak will sound like a leak...
Old Feb 15, 2005 | 04:56 AM
ironlung78's Avatar
hold a lit cigarette, or in some cases a joint up to where you think it is leaking. If the direction of the smoke changes then you have a leak
Old Feb 15, 2005 | 05:13 AM
remo's Avatar
soapy water does the trick
Old Feb 15, 2005 | 05:14 AM
khmboostedeh2's Avatar
Default Re: how do u check for an exhaust leak? (remo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remo &raquo;</TD></TR><TR><TD CLASS="quote">soapy water does the trick</TD></TR></TABLE>
yes but not most practical. works good for tires though.
Old Feb 15, 2005 | 05:17 AM
remo's Avatar
Default Re: how do u check for an exhaust leak? (Jeterkm02)
it does leave dried crap on stuff . ..
Old Feb 15, 2005 | 06:58 AM
kurzsi's Avatar
put a frisby on the end of ur exhaust and air will escape from wherever the leak is
Old Feb 15, 2005 | 10:28 AM
boosted ek's Avatar
Default Re: how do u check for an exhaust leak? (kurzsi)
i'm gonna try the cigarette trick.
Old Feb 15, 2005 | 10:32 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurzsi &raquo;</TD></TR><TR><TD CLASS="quote">put a frisby on the end of ur exhaust and air will escape from wherever the leak is</TD></TR></TABLE>
I advise against this. like wow. If your not careful thats asking for trouble.
Old Feb 15, 2005 | 11:04 AM
96MidoriHatch's Avatar
Default Re: how do u check for an exhaust leak? (Luserkid)
you probably dont have one at home, but we use a smoke machine with a rubber fitting on the outlet that fits inside the tail pipe.
Old Feb 15, 2005 | 11:05 AM
boosted ek's Avatar
Default Re: how do u check for an exhaust leak? (96MidoriHatch)
muffler shop has this?
Old Feb 15, 2005 | 11:46 AM
monicle's Avatar
hehe yeah this will work all of a few seconds untill the car stalls. why do you think people shove potatos into tale pipes to mess with people?
Old Feb 15, 2005 | 11:51 AM
Unjockable's Avatar
New User
Default Re: how do u check for an exhaust leak? (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">hehe yeah this will work all of a few seconds untill the car stalls. why do you think people shove potatos into tale pipes to mess with people?</TD></TR></TABLE>
to check for leaks?
Old Feb 15, 2005 | 04:48 PM
Default Re: how do u check for an exhaust leak? (Unjockable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted ek &raquo;</TD></TR><TR><TD CLASS="quote">muffler shop has this?</TD></TR></TABLE>
i would think so, maybe the higher end ones, I'm not sure though.
Old Feb 15, 2005 | 04:51 PM
VTiVTo8000rpm's Avatar
Default Re: (boosted ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted ek &raquo;</TD></TR><TR><TD CLASS="quote">just to make sure, exhaust leak with cause a rattle/stutter sound, right?</TD></TR></TABLE>
Sounds like you have a broken weld, just raise it up and inspect it starting from the header to the exhaust tip.
Old Feb 16, 2005 | 01:55 PM
kurzsi's Avatar
Default Re: (VTiVTo8000rpm)
actually if u have an exhaust leak air getting out somewhere so obviously your car wouldn't shut off. THINK ABOUT IT
Old Feb 16, 2005 | 01:58 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (kurzsi)
So the same amount of air will go easily out an opening less than the size of a penny just as easily as it will out your 2" exhaust pipe?
Old Feb 16, 2005 | 02:01 PM
zombie247's Avatar
1) Get the car in the air. Or so that you can get under it. SAFELY
2) Cut/find a piece of vaccum hose.
3) Use it stethoscope style. One piece in ear other in hand.
4) locat area where you might think it could be coming from. Such as the areas where the exhasut bolts to gether.
5) just listen for wind/noise.
*EDIT - oh ya, this works even better when the car is running, put that in one of those s1teps.
Modified by zombie247 at 5:11 PM 2/16/2005
Old Feb 16, 2005 | 02:04 PM
dantastic's Avatar
bigger exhaust leaks will leave streaks of soot around the leak. piping on newer cars hardly every rusts through. check at the flanges/joints 1st
Old Feb 16, 2005 | 02:08 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurzsi &raquo;</TD></TR><TR><TD CLASS="quote">actually if u have an exhaust leak air getting out somewhere so obviously your car wouldn't shut off. THINK ABOUT IT</TD></TR></TABLE>
if the leak was big enough to allow the car to run when the end is plugged up it would be big enough to hear and see the huge gaping hole THINK ABOUT IT
LsHoney84
Apr 1, 2006 02:47 PM
GDM Z28
Mar 11, 2004 02:23 PM
JunIntegra
Jan 8, 2004 04:57 AM
twisted_1
Aug 29, 2003 02:13 PM
InfamousRS
Feb 9, 2002 08:39 AM
