450 cc injectors add resistors or no?
I have a 90 teg with a b16a and a pr3 ecu i want to run the 450 cc dsm injectors and i am unclear if i have to add the resistors or not to get them to work i will be running a turbo setup and if there is anything else i would need to get them to work ....
thanks
thanks
Well the 450's need resistors.
If you still have this connected, then you're golden. If not you'll have to solder in some 10 watt/10 ohm resistors inline with the injectors. Your other option is to reconnect the resistor box that the car came with, pictured above on my 91.
Oh yeah, if you do need to install the resistor box I found a couple good links with pics.
https://honda-tech.com/zerothread?id=517274
https://honda-tech.com/zerothread?id=658096 <-- 5th post down
