Got a code 23(knock Sensor) and the engine is not knocking.
Old Feb 13, 2005 | 08:54 PM
aznplyboi15's Avatar
Default Got a code 23(knock Sensor) and the engine is not knocking.
Got a civic hatch with GSR and it is flashing a code 23, from what i know the car is not knocking. Is there any other signs to tell if i really need a new knock sensor. I really don't want to by another one if i dont have too.
Please Help. Thank You!!
Old Feb 13, 2005 | 09:06 PM
f1z1c's Avatar
Default Re: Got a code 23(knock Sensor) and the engine is not knocking. (aznplyboi15)
See if you get less knock with higher octane. Your ingition or cam timing could be slightly off.
Old Feb 13, 2005 | 09:12 PM
Default Re: Got a code 23(knock Sensor) and the engine is not knocking. (f1z1c)
what should the time be set at?
Old Feb 13, 2005 | 09:47 PM
.1type.'s Avatar
timing so be at 16
Old Feb 14, 2005 | 07:22 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Got a code 23(knock Sensor) and the engine is not knocking. (1type)
Did you use "shielded wire" for the knock sensor, when you did the swap? That can cause EM interference to read as knock to the ECU...
Old Feb 14, 2005 | 07:39 AM
spoonek9's Avatar
Check to make sure it isn't loose or anything too.
Old Feb 14, 2005 | 09:37 AM
dukduk's Avatar
Default Re: Got a code 23(knock Sensor) and the engine is not knocking. (spoonek9)
look and make sure the sensor isn't physically broken...i busted mine when putting on the edelbrock mani
mxracer420
Apr 27, 2009 08:44 PM
9deuce9rr
May 16, 2005 08:40 PM
Fardoche
Jul 31, 2003 10:29 PM
smslude
Jan 14, 2003 10:37 PM
