b16a semi-built vs. jdm b18c-r
Old Feb 13, 2005 | 12:11 PM
Rice Is Best's Avatar
Default b16a semi-built vs. jdm b18c-r
jdm stock bottom end with b18 crank
jdm b16a head
itr intake manifold
itr exhaust manifold
jdm b16a tranny
VS.
jdm itr b18cr
would changing the crank of a b16a and intake and exhaust manifold compare anywhere near a b18cr?
how can you make a b16a become a stock itr b18c-r?
Old Feb 13, 2005 | 12:13 PM
Luserkid's Avatar
Default Re: b16a semi-built vs. jdm b18c-r (Rice Is Best)
Look up Poormans Type R.... thats how.
Old Feb 13, 2005 | 12:14 PM
Default Re: b16a semi-built vs. jdm b18c-r (Luserkid)
so a poormans type r is basically a type r? 99% the same?
Old Feb 13, 2005 | 12:16 PM
Luserkid's Avatar
poormans type R is a b18 bottom (either LS, or GSR) and B16 head.
You wont get the B18 torque with a B16 unless you go FI.
Old Feb 13, 2005 | 12:17 PM
yea but im sure just by changing the b16 crank to the b18 crank, it turns out to be a b18.
so b16 block
b18 crank
b16 head
type r IM
type r EM
b16 tranny
all those should make a type r right?
Old Feb 13, 2005 | 12:21 PM
Resident Evo's Avatar
You would also need a set of CTR or maybe itr cams & itr valvesprings for that top end powah.
Old Feb 13, 2005 | 12:28 PM
egsleepercivic's Avatar
I think if you put a b18 crankshaft into a B16a that your pistons would smash into the head, someone correct me if I am wrong
Old Feb 13, 2005 | 12:30 PM
Default Re: (egsleepercivic)
this is basically what i want to know.
Old Feb 13, 2005 | 01:30 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I think if you put a b18 crankshaft into a B16a that your pistons would smash into the head, someone correct me if I am wrong</TD></TR></TABLE>
I believe you are 100% correct.
B16 stroke = 77.5
B18 stroke = 87.2
It would be alot easier just to get a B18 bottom end. Whats wrong with doing that?
Old Feb 13, 2005 | 01:36 PM
JDMlyfestyle's Avatar
yes if u put that B18 crank in the B16 you will demolish you head.
Be like me Represent the B16's!!! Own a R or H22hatch like whoa
Old Feb 13, 2005 | 02:41 PM
00Red_SiR's Avatar
All Motor Mentor
This is correct, but if you do a search in the all motor forum, you'll see a couple people that have done just what you're asking about. If you put a B18c crank and rods into a B16a block, you'll need some custom made shorter pistons which are available specifically for this setup and you can have a B18c in a B16 block. The only real advantage to doing this is the sleeper effect. I've seen a 2.0L configuration like this in a B16 block and head setup so when you lift your hood, everyone thinks you only have a B16 engine in there.
Modified by 00Red_SiR at 11:32 PM 2/13/2005
Old Feb 13, 2005 | 02:51 PM
yup tech43 makes custom raised pin Pistons all the way up to 85 mm for that sleeper look
Old Feb 13, 2005 | 05:15 PM
Default Re: (00Red_SiR)
nice!!!
Old Feb 13, 2005 | 07:15 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Rice Is Best)
Here's a link to a guy doing something similar in the all motor section:
https://honda-tech.com/zerothread?id=1057340
jfruauff
Sep 2, 2008 01:32 PM
Jose-aka-Pedro
Feb 6, 2007 12:52 PM
b16a27
Dec 4, 2004 11:14 AM
conceptEG
Sep 4, 2003 11:45 AM
H22CIVIC
Oct 2, 2001 11:45 AM
