Swap for the 2000 si
I have a 2000 si and i was looking into swapping the bottom end, but im not sure what to swap in, i have been getting different answers from people i know, but half of them dont know anything, if im correct swapping the bottom end would be better then swapping the whole engine because the b16 head has better flow, any posts would be appreciated.
http://www.hmotorsonline.com/s...30024 sell head stick yours on
or
http://sportcompactcarweb.com/tech/0411scc_hybrid/
or
And B-series VTEC bottom end (B16B, B18C1 or B18C5) will bolt directly up to your head. Any B-series non-VTEC bottom end will take the Golden Eagle kit or machining to fit, but you'll get more displacement (B20A/Z or B18B).
My suggestion is the B18C1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raver01x »</TD></TR><TR><TD CLASS="quote">you could get an ls block with the crank and connecting rods and use your b16 pistons and do an ls/vtec </TD></TR></TABLE>
good h/c combo
good h/c combo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">And B-series VTEC bottom end (B16B, B18C1 or B18C5) will bolt directly up to your head. Any B-series non-VTEC bottom end will take the Golden Eagle kit or machining to fit, but you'll get more displacement (B20A/Z or B18B).
My suggestion is the B18C1.</TD></TR></TABLE>
nuff said
. I went the LSVtec route tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 »</TD></TR><TR><TD CLASS="quote">B18C5 short block new from Acura...can't go wrong there IMO</TD></TR></TABLE>
arent those like 6 grand form the dealer?
CK_4500
Apr 6, 2010 06:34 AM
