b20b or b20z??
ok as i was told the b20b block has a lower compression then the b20z....correct me if im wrong....and normally if you would go with a turbo set up you would want lower compression right??...and for lower compression i would want the b20b ??...different ppl keep on telling me different things...reason imaskin is because i want to run a b20 block with a type r head and then tubo it...and a b20b block is alot easier and cheaper to come by then the b20z....i was gonna get new rods and pistons anyways and i was told that even if i do that the b20b block is built differently then the b20z and would not be able to handle much and that it would give on me...could anyone tell me the facts on this thing so i could hurry and pick up a block...and finish my project...thanx
JDM_ego2033
Jun 25, 2019 05:30 PM
IT'S ME DAVID
Jul 1, 2005 12:14 PM
Casey
Dec 17, 2002 12:30 PM
